Is The Gas Valve Bad? - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 10-12-2008, 03:55 PM   #16
Originally Posted by beenthere View Post
I seldom test thermos anymore.
I install a new one.
If the valve is bad instead. No problem. I don't install new valves and leave old thermos in.
I don't test anymore either. It takes longer to test that to replace. And for the $4 I don't have to come back for a marginal thermo that only had a few months left anyhow.
When I do annuals I replace the thermo if it is over 2 years old. I figure they are paying me for something and this keeps me from coming back a few months later. Nothing like having a furnace fail right after you did an annual on it.
My idea of a perfect day: No where to go and all day to get there.
Marvin Gardens is offline   Reply With Quote
Old 10-12-2008, 10:08 PM   #17
That is not testing it under load.
Under load, would be while its hooked to the gas valve.
I found a lot of t couples that will test good that way, but are weak. When tested underload, they test out at 20 or less mV.
The clip could be bad, and letting the t couple slide away from the pilot flame.
If its not.
Install a block, and check it while under load. If it test ok then. You probably have a bad gas valve.
Keep in mind, that if it is a gas valve. You should still install a new t couple.
Maybe i am confusing matters here. I sold coleman 78%ers for a while and the Robertshaw redundant valve had grooves vetical on the pilot operator.
You could check the mv with the tcouple attached to the valve with the burners lite,.
Sorry I was a little slow on the up take. The open circuit and closed circuit test. That's basic stuff but it's been so long since I saw a standing pilot ...
But Been He did say the top quarter was enveloped with a good flame.
But he's going by the customer telling him the t'couple was new.
Put in a new one and see what happens.
hvaclover is offline   Reply With Quote
Old 10-12-2008, 10:59 PM   #18
An old Tradesmen
Rewards Points: 6,098
A lot of newer valves do have the cut out for checking under load.
But not all. And there are still a lot of older vavles out that don't have the cut out.
So I carry the block.
Probably have the time that I do check them. I use the block when I could use the tabs at the cut out. But I can't use clips thens.
Old habits are hard to break.
Old 10-12-2008, 11:03 PM   #19
Tell me about it.
Hey Been! I just back from the casino. I broke even That means I won
Old 10-12-2008, 11:10 PM   #20
An old Tradesmen
I haven't been to a casino for a Year or so.
I take down X amount of money, and if I have gas money left, I did ok. LOL
Old 10-12-2008, 11:21 PM   #21
There's been too much drama at home..Mama Clover needed some "Get me the hell out of the house" time.
When she hits a losing streak she cusses the slots like a tech does an obstinate furnace..lol..lucky it's ll in Greek.
i get mad sometimes too, have to walk away from the slot and get a beer to cool down.
Had a little heartbreak of my own too. Bought a Fluke for the first time, a 116. Found out it was made in china.
Also been hearing the guys complain about the quality.
Looks like it's going back
Old 10-12-2008, 11:27 PM   #22
An old Tradesmen
The quality of everythng goes down, when cost have to be cut.
Old 10-12-2008, 11:30 PM   #23
Would you keep it? I always used UEI before.
Old 10-12-2008, 11:34 PM   #24
An old Tradesmen
I would keep it. Just to say i have a Fluke.
I use Fieldpiece. I don't have any problems with them.
My manometer is a Testo though, much better then fields.
I find if you drop them off the roof of a 3 story building, it breaks as well as a Fluke. Just cost less to replace.
ball valve leaking bwall Plumbing 10 12-31-2012 08:25 PM
Toilet: water still coming from BOTTOM of Inlet Valve DIY Mom Plumbing 1 08-12-2008 01:43 PM
Best 1/2 inch water shut off valve. Nestor_Kelebay Plumbing 10 07-25-2008 12:16 PM
Can't reinstall shower valve properly ptoneil Plumbing 3 04-10-2008 11:05 PM
