Is The Gas Valve Bad? - HVAC - DIY Chatroom Home Improvement Forum
Old 10-25-2011, 08:54 AM   #1
is the Gas valve bad?
When i lite the pilot and turn up the temp. the burrners light and the blower comes on. When i turn the temp down the pilot goes out. this happens two out of three times? I have already replaced the thermocouple. It seems as though if i leave the burners on for aprx 10 min. the pilot stays lit when i turn the temp down. However if i turn the burners on then quick turn them off the pilot goes out. Any thoughts?
benm is offline   Reply With Quote
Old 10-25-2011, 10:20 AM   #2
how
Rewards Points: 1,104
Say what brand ,style & model of furnace you have.
The Pilot orifice may be dirty, meaning that the pilot flame is soft enough to be affected by the natural draft which is pulling its flame away from the thermocouple. Watch the pilot flame to see if it is being pulled or pushed away from the thermocouple at any point in your heating cycle.
Concussive ignition or shut down of the main burners knocking out the pilot.
Lots of possibilities.
Doing a closed thermocouple test with a dcmv thermocouple adapter is the usual first step.
how is offline   Reply With Quote
Old 10-25-2011, 06:28 PM   #3
I've also seen many a standing pilot be blown out from holes in rusted out heat exchangers. If you have not had an annual inspection yet get it done.
How to diagnose gas valve problems Nestor_Kelebay How To Guides 28 10-30-2013 04:19 PM
pressure relief valve is leaking on boiler wlmpdiycr HVAC 65 10-26-2011 05:00 PM
Toilet: water still coming from BOTTOM of Inlet Valve DIY Mom Plumbing 1 08-12-2008 12:43 PM
Best 1/2 inch water shut off valve. Nestor_Kelebay Plumbing 10 07-25-2008 11:16 AM
