Gas Valve - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 07-28-2011, 05:25 PM   #16
the Musigician
DangerMouse's Avatar
This one stays, the other is gone.
DM
Old 07-28-2011, 05:34 PM   #17
Ok, I won't. Thanks for all the help./ I'll try the repositioning first. Bill
BillJ is offline   Reply With Quote
Old 07-28-2011, 05:42 PM   #18
Hvac Pro
yuri's Avatar
Rewards Points: 386
Be CAREFUL. You could be held liable/sued if you alter anything and a delayed ignition/explosion happens later.
Old 07-28-2011, 06:31 PM   #19
I will, thanks
Old 07-28-2011, 06:34 PM   #20
Hvac Pro
yuri's Avatar
Rewards Points: 386
Technically and legally the furnace is only AGA/CGA gas code and UL certified for the original OEM parts. Using generic or other parts if they create a problem could give a smart ambulance chasing lawyer a good case to clean you out of everything you own or have worked for.
How to diagnose gas valve problems Nestor_Kelebay How To Guides 28 10-30-2013 04:19 PM
Cant get the valve off (with picture) clof2001 Plumbing 3 05-10-2010 03:04 AM
Help w/ mixing valve (I think) ink HVAC 15 02-28-2010 10:01 PM
Toilet: water still coming from BOTTOM of Inlet Valve DIY Mom Plumbing 1 08-12-2008 12:43 PM
Best 1/2 inch water shut off valve. Nestor_Kelebay Plumbing 10 07-25-2008 11:16 AM
