Gas Value Won't Stay Open On A Goodman Furnace Gmpn100-4 - HVAC - DIY Chatroom Home Improvement Forum
Old 01-06-2011, 10:45 AM   #1
gas value won't stay open on a goodman furnace gmpn100-4
The gas will shut off shortly after the hot surface ignitor (glow plug) turns off. I can force the valve to stay open to let the furnace heat the house. This problem is intermittent and after forcing the value to stay open, the furnace will run normally for 6-12 hours and then needs attention again. I've replaced the computer board with no luck. The last part in my thinking is that the valve is defective. Any assistance anyone has with this would be appreciated.
kevinmargo is offline   Reply With Quote
Old 01-06-2011, 12:34 PM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 136
If the circuit board is not grounded properly on Goodmans like yours they can get damaged. Read this post. May need a new board now.
Goodman 100-3
Goodman GMP Furnace won't stay lit. JoelT HVAC 10 12-16-2012 11:24 AM
Propane furnace pilot wont stay lit davewest HVAC 0 11-21-2009 12:19 AM
bryant gas furnace burner wont stay on. pipebender HVAC 29 11-08-2009 07:41 PM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 01:55 PM
Goodman furnace: won't start Guyver03 HVAC 2 10-23-2006 02:25 PM
