Gas System Check - HVAC - DIY Chatroom Home Improvement Forum
Old 10-01-2012, 11:17 PM   #1
Rewards Points: 150
gas system check
Hey I'm just starting my company and have been doing service and checks for a few months now. I am starting to get calls for no heat, and gas heat service. I was wondering what checks need to be done on gas heat to make sure every thing is running well. What tools/ meters do I need to purchase? I have flute and field piece for the ac side and heat pumps, but nothing for nat gas. I know how to check the pressure coming in the then through the gas valve (11 WC for nat gas). I was thinking there was a fume detector or something I needed. something to check to flame maybe, not sure what all I need.
Thanks for the help
wetbar is offline   Reply With Quote
Old 10-01-2012, 11:46 PM   #2
Rewards Points: 582
Thanks for the help
please take this the right way....you need more education on the operation of natural gas furnaces and saftey before you start working on them..... peoples lives are at risk.....Iam sure you mean well and i wish you the best .. ben sr
The Following 2 Users Say Thank You to ben's plumbing For This Useful Post:
COLDIRON (10-02-2012), hvactech126 (10-02-2012)
Old 10-01-2012, 11:58 PM   #3
Missouri Bound's Avatar
What experience do you have which gave you the initiative to start your own business? You have entered a field which deals with comfort and safety and you have some questions as to how to perform your job properly? I don't know your situation, but if you are able to hire somebody whith the techinical ability and knowledge to do these tasks you will be much better off. As far as you personally, you need to get training to work on the systems which you are servicing. You are opening yourself up to a great amount of liability should one of your service calls goes awry.
Do you want it your way or the right way?
The Following 3 Users Say Thank You to Missouri Bound For This Useful Post:
ben's plumbing (10-02-2012), COLDIRON (10-02-2012), hvactech126 (10-02-2012)
Old 10-01-2012, 11:58 PM   #4
Seconded.
hvac benny is offline   Reply With Quote
The Following 3 Users Say Thank You to hvac benny For This Useful Post:
Old 10-02-2012, 12:03 AM   #5
AKA HVACTECHFW
Rewards Points: 1,208
Originally Posted by ben's plumbing View Post
please take this the right way....you need more education on the operation of natural gas furnaces and saftey before you start working on them..... Peoples lives are at risk.....iam sure you mean well and i wish you the best .. Ben sr
ditto
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
The Following User Says Thank You to hvactech126 For This Useful Post:
Old 10-02-2012, 12:14 AM   #6
Rewards Points: 150
I have been doing hvac service for years, I just don't do a lot of gas. And the gas I have done has always been pressure switch, blowers, bad boards and stuff like that. I have been repairing them for years but have never done a complete service and checkup. I don't have a combustion analyzer or anything like that,
Just wondering what everyone else was doing and using.
Old 10-02-2012, 12:17 AM   #7
Are you certified to work on gas?
Old 10-02-2012, 12:19 AM   #8
JJboy's Avatar
Tools:
Multimeter
Manometer
CO detector
You need to check:
Inducer motor amps
Blower motor amps
Capacitor if it's on the manufacture range
Leak on heat exchanger
Pressure switch
Check safety circuit if it is working properly
Simulate if the high limit will open without blower motor running.
Flame sensor microamperes
Gas valve pressure
Ignitor is working ok
Burners are clean.
drain line
Overall clean
You need to know operation for:
80% single stage
80% 2 stage
90% single stage
90% 2 stage
**Always kill the power ** Hot air rises, but heat will always move from higher to lower temperatures. ** Real man shoot in manual. ** If it ain't grounded, it ain't dead.
JJboy is offline   Reply With Quote
Old 10-02-2012, 12:20 AM   #9
Jjboy...I give up..what does "real man shoot in manual" mean in your tag line?
Old 10-02-2012, 12:24 AM   #10
JJboy's Avatar
This is related to photography .... means not shooting in automatic (A)
Old 10-02-2012, 12:26 AM   #11
Rewards Points: 582
hey missouri wow even i knew that....click click...
Old 10-02-2012, 12:28 AM   #12
Rewards Points: 614
I agree ...you have a basic fundamental of natural gas wrong.... you need to figure out the pressure before you buy anything....
carmon is offline   Reply With Quote
The Following 3 Users Say Thank You to carmon For This Useful Post:
Old 10-02-2012, 12:38 AM   #13
Rewards Points: 150
What do you mean pressure? Nat gas is 11.7 - 12.2 of WC for perfect combustion. I know Propane is a little higher, but we mainly see natural gas around here. Am I wrong?
Old 10-02-2012, 12:41 AM   #14
Pressure alone won't tell you jack about combustion, let alone perfect combustion.
Old 10-02-2012, 12:45 AM   #15
Rewards Points: 614
nothing good gonna come of this.... my lips are sealed.... read some books ...fast....
The Following 2 Users Say Thank You to carmon For This Useful Post:
ben's plumbing (10-02-2012), hvactech126 (10-02-2012)
New Sump System - Sewer Gas peterhil Plumbing 0 02-28-2012 04:53 PM
Installing Pool System New v. Used? flowerchick General DIY Discussions 5 10-27-2011 08:28 AM
Permit For Fire Sprinklers letnes Plumbing 18 10-14-2010 06:23 PM
beware humidity system? Emaderton3 HVAC 5 02-11-2010 12:52 AM
Which heatings system should I go with? keano016 HVAC 5 12-01-2009 03:53 PM
