Gas Stove Vent To Gas Pipe Clearance? - HVAC - DIY Chatroom Home Improvement Forum
Old 06-15-2009, 06:09 PM   #1
Gas stove vent to gas pipe clearance?
I recently purchased a new natural gas stove and gas barbecue.
Gas Stove: Napoleon GDS25
http://www.napoleonfireplaces.com/St...gas/gds25.html
I have looked through the installation/user manual and it does not give a specific reference to the required clearance of the through wall vent and the vent hood proximity to the metal gas supply line.
I am trying to figure out if I need to re-route my gas lines or if I have adequate clearance to the stove vent.
I beleieve that the 1" gas pipe on the exterior of my house would be approxiamtley 12" above the vent hood. I am hoping it is ok, but want to know if I should re-route or not.
rbarr110 is offline   Reply With Quote
Old 06-15-2009, 06:32 PM   #2
I have looked in the mechanical code and it says that the vent should not be within 3 feet of the meter service outlet.... once again nothing restricting vent to gas pipe.
Help please!
Old 06-15-2009, 07:33 PM   #3
Common sense prevails in this case(hot surface against a medium carrying a highly flammable substance just goes against my grain) . Although I have never exposed a flue to gas pipe I have seen it done on some hack furnace installs.
Just make sure there is no contact on the gas pipe form any hot surface.
hvaclover is offline   Reply With Quote
Old 06-15-2009, 08:36 PM   #4
HVAC / Plumbing
Help please!
If your talking about sch. 40 gas pipe .. there is no clearence requirments.. Your range vent / exhaust won't affect it
kenmac is offline   Reply With Quote
Old 06-15-2009, 08:43 PM   #5
of course you're right. But there is just something about letting it touch that screams "NOOOOO" to me
Old 06-15-2009, 08:49 PM   #6
HVAC / Plumbing
he probably has an exhaust fan for the range. that would cool down the exhaust gasses in the vent as it would be exhausting some air within the home as well
Old 06-16-2009, 12:14 PM   #7
I guess I should clarify, its not a cooking range type stove, but a free standing gas fireplace. I am not sure if the exhaust is a power exhaust, I will have to check on that.
So there is likely a good amount of heat coming oout of the fireplace vent.
The gas supply line in question is 1" the "black iron" pipe. I honestly dont know what the exisiting pipe schedule is, but 40 sounds correct. I appreciate the input.
I have the same question in with a friend that works for the manufacturer of the fireplace as well.
This is similiar to what I will have without the brick..... imagine a small 1" diameter pipe above the vent ( maybe 10-12")for my particular situation.
Old 06-17-2009, 04:14 PM   #8
Any second opinions since it is not a range stove, but a free standing fireplace stove?
I have a hard time beleiving it would be an issue since the vent has to be more than 2" from a combustible in the wall. The pipe is non-combustible.
Old 06-17-2009, 04:36 PM   #9
HVAC / Plumbing
no problems
stuck iron pipe on oil tank vent wrybosome Plumbing 3 01-13-2009 10:43 PM
Where is the toilet vent?!?!? domgbrown Plumbing 4 01-11-2008 07:33 PM
can I 'patch in' a bathroom vent into my kitchen's stove hood vent? joeyboy HVAC 2 09-10-2007 01:36 PM
Vent Pipe Leak romeguy1 Plumbing 9 12-11-2005 01:08 AM
