Gas Stove Pilot Light Gas Use? - HVAC - DIY Chatroom Home Improvement Forum
Old 01-09-2013, 09:02 AM   #1
Rewards Points: 736
This is a kind of silly question, but it can't hurt to ask : the pilot light in our gas stove (one of those living room supplemental heat / decorative units) is... to put it lightly, huge. We used the stove only a handful of times in the past month and yet somehow used 100 dollars worth of propane ( the stove is the only thing using the propane, right now ). I realize these things aren't at all efficient, but my question is :
- is the pilot light deceiving, or do some of them really use a larger-than-normal amount of gas
- is there any harm, aside from the hassle, in turning the pilot off and re-igniting by hand every time we use the thing (once a week if that, usually less)?
Here's a picture of the stove for reference (pic is from the summer, we don't put things on top / near it in the winter, obviously)
TheBobmanNH is offline   Reply With Quote
Old 01-09-2013, 09:25 AM   #2
Roofmaster
Rewards Points: 2,210
Is this a converted wood stove? Im surprised at the flue on this thing. I have a vent free gas log, so even the pilot heats the house. I turn it off in the spring, on in the fall, cause it does put out heat. I am on NG though, which is cheaper than LPG, from what I understand.
Your heat is going up the flue, no?
Old 01-09-2013, 10:15 AM   #3
Rewards Points: 736
Honestly? I have no idea. We bought the house over the summer, and this was all there when we moved in. There may have been a wood stove in the place of this gas one at some time and they just repurposed the flu. The stove itself is designed as a gas stove. Though I vaguely remember looking the thing up online (to see what it cost) and it had that kind of pipe straight from the factory. Might be mostly decorative....
Old 01-09-2013, 03:39 PM   #4
An old Tradesmen
Rewards Points: 7,330
On some the pilot can be adjusted down. No harm in turning it off. You may have a small leak outside somewhere.
Old 01-09-2013, 03:43 PM   #5
Roofmaster
What is the make of the stove? Looks like a Vermont Castings Knock Off.
Old 01-09-2013, 05:45 PM   #6
Rewards Points: 13,712
No way should it have used that much gas. I'd be calling the gas company to come do a pressure test to check for leaks.
I know mine will do it for free.
Old 01-10-2013, 08:49 AM   #7
Rewards Points: 736
They came and tested the whole system for leaks when we first moved in, and replaced the tank (it was old, not leaking). We used the stove much less since that first fill-up, so I'm curious to see what the next fill-up will cost before I fully blame the pilot or a leak.
Old 01-10-2013, 09:27 AM   #8
Rewards Points: 736
I don't know that I'd call ti a "knock off", it's a nice unit. I remember looking up the brand when we first bought the house and it's perfectly reputable, but I don't remember it off the top of my head now.
EDIT : The brand on the back says "Aladdin." It's a Quadra-Fire Topaz. http://www.quadrafire.com/en/Product...Gas-Stove.aspx
Can a standing pilot use electronic ignition? richapple HVAC 20 11-26-2012 11:45 PM
Question on the ever popular pilot light Bushman HVAC 5 10-14-2012 01:35 PM
Two 3-way switches: one pilot light, one regular flitz Electrical 14 08-20-2012 06:46 PM
Pilot Light works once, then have to re-light after furnace goes off aransas42 HVAC 8 09-30-2009 07:49 AM
Is a pilot light supose to stay on? simonb HVAC 2 06-11-2008 05:16 PM
