Gas Stove Pilot Light Gas Use?
This is a kind of silly question, but it can't hurt to ask : the pilot light in our gas stove (one of those living room supplemental heat / decorative units) is... to put it lightly, huge. We used the stove only a handful of times in the past month and yet somehow used 100 dollars worth of propane ( the stove is the only thing using the propane, right now ). I realize these things aren't at all efficient, but my question is :
- is the pilot light deceiving, or do some of them really use a larger-than-normal amount of gas - is there any harm, aside from the hassle, in turning the pilot off and re-igniting by hand every time we use the thing (once a week if that, usually less)? Here's a picture of the stove for reference (pic is from the summer, we don't put things on top / near it in the winter, obviously) http://i75.photobucket.com/albums/i3...psf2b99cc2.jpg |
Is this a converted wood stove? Im surprised at the flue on this thing. I have a vent free gas log, so even the pilot heats the house. I turn it off in the spring, on in the fall, cause it does put out heat. I am on NG though, which is cheaper than LPG, from what I understand.
Your heat is going up the flue, no? |
On some the pilot can be adjusted down. No harm in turning it off. You may have a small leak outside somewhere.
What is the make of the stove? Looks like a Vermont Castings Knock Off.
No way should it have used that much gas. I'd be calling the gas company to come do a pressure test to check for leaks.
I know mine will do it for free. |
EDIT : The brand on the back says "Aladdin." It's a Quadra-Fire Topaz. http://www.quadrafire.com/en/Product...Gas-Stove.aspx |
| All times are GMT -4. The time now is 01:05 AM. |
