Gas Steam Boiler - HVAC - DIY Chatroom Home Improvement Forum
Old 12-12-2008, 06:33 PM   #1
gas steam boiler
When the thermostat calls for heat the boiler goes on. However, the pressure gauge doesn't budge, and the boiler will stay on until it uses up all the water, then the low water switch turns it off. I am worried that the boiler can overheat, and I am wondering if the pressure control could be faulty or the RETARD gauge faulty Right now I manually turn the thermostat up and then turn it down to 60 degrees after 10 minutes and I feel some heat coming through the radiators
Gary T is offline   Reply With Quote
Old 12-12-2008, 06:42 PM   #2
Could be that the plumbing going to the pressure switch is plugged. I would check this first.
SKIP4661 is offline   Reply With Quote
Old 12-12-2008, 07:17 PM   #3
Hvac Pro
yuri's Avatar
Rewards Points: 136
If the boiler is cutting out on the low water cutoff then the fill valve is not working. Some of them are combination low water cutoff/fill valve and they need to have the sludge blown out/down regularly AND a yearly checkup/cleaning of that control by a pro who understands/services steam boilers. Get it done properly ASAP or you may have a bomb on your hands next time.
Old 12-12-2008, 09:33 PM   #4
An old Tradesmen
Rewards Points: 7,814
Where is the steam/water going to.
Are you manually adding water to the system.
Or is the level coming back up by the time you turn the stat up again.
Is this a single or 2 pipe system.
Converting steam heat to hot water??? pcampbell HVAC 31 02-17-2009 08:26 PM
Ignition problems ongas boiler for steam system NickG HVAC 1 11-12-2008 01:00 PM
Converting Steam Radiators To Hot Water johnpar HVAC 4 07-30-2008 03:34 PM
Steam boiler corrosion problem franklopes HVAC 4 11-09-2006 08:02 PM
Flushing a Steam Heat Furnance helpless handyman HVAC 2 11-06-2006 04:34 PM
