-   -   gas steam boiler (http://www.diychatroom.com/f17/gas-steam-boiler-33656/)
Gary T 12-12-2008 07:33 PM
gas steam boiler
When the thermostat calls for heat the boiler goes on. However, the pressure gauge doesn't budge, and the boiler will stay on until it uses up all the water, then the low water switch turns it off. I am worried that the boiler can overheat, and I am wondering if the pressure control could be faulty or the RETARD gauge faulty Right now I manually turn the thermostat up and then turn it down to 60 degrees after 10 minutes and I feel some heat coming through the radiators
SKIP4661 12-12-2008 07:42 PM
Could be that the plumbing going to the pressure switch is plugged. I would check this first.
yuri 12-12-2008 08:17 PM
If the boiler is cutting out on the low water cutoff then the fill valve is not working. Some of them are combination low water cutoff/fill valve and they need to have the sludge blown out/down regularly AND a yearly checkup/cleaning of that control by a pro who understands/services steam boilers. Get it done properly ASAP or you may have a bomb on your hands next time.
beenthere 12-12-2008 10:33 PM
Where is the steam/water going to.
Are you manually adding water to the system.
Or is the level coming back up by the time you turn the stat up again.
Is this a single or 2 pipe system.
