Gas Pressure Question / Big Pilot Flames - HVAC - DIY Chatroom Home Improvement Forum
Old 01-24-2011, 08:11 PM   #1
Gas pressure question / big pilot flames
I have a natural gas 10k blue flame ventless heater with a big noisy pilot flame in the basement as supplemental heat down there, and a natural gas vented fireplace log set in another room also with a big noisy pilot flame. I called the gas company to ask them to check my pressure but they only do that for low pressure concerns - not high.(!). The house was built in the 50s and near before I bought it 2yrs ago the prior owner replaced what I'm sure judging from old ductwork was a big dinosaur of a furnace with a high efficiency Bryant 90i. I replaced the natural gas water heater last year and that was a 1994 model. I would imagine my current natural gas demand is much less than the house was previously demanding. Picking a gauge to measure nat gas pressure seems a lil complex, do I use psi or water columns... splurge for a gauge that does both? Looks like a gauge is $50 for something I'll use maybe twice The blue flame heater and the fireplace log set have regulators within them, so even if the pressure were high no biggee? Am I worrying about nothing? Strictly speaking all gas appliances work a-ok, and the pilot for the hot water is sealed in so I can't judge it's size/noise very well. Appreciate any thoughts!
Mrdippy is offline   Reply With Quote
Old 01-25-2011, 02:42 AM   #2
An old Tradesmen
Rewards Points: 6,846
Gas pressure is generally measured in inches of water column.
Look at the gas valves. Should have an adjustment for the pilot.
Old 01-25-2011, 12:52 PM   #3
HVAC / Plumbing
Those heaters usually have good size pilots. There usually long and thin pointed ( sort of) at the tip
kenmac is offline   Reply With Quote
Old 01-25-2011, 05:06 PM   #4
Make your own manometer for a couple bucks. Do a Google search. Pretty simple and dead-on accurate.
artbuc is offline   Reply With Quote
Old 01-25-2011, 06:51 PM   #5
Thanks for the ideas! I have some new ideas to run down on this. I will make a manometer to put my mind at ease.
Old 01-26-2011, 07:09 AM   #6
Make sure you read the bottom of the meniscus.
Pilot light button on furnace won't turn whydonchathen HVAC 8 01-19-2015 10:40 AM
Pressure Switch Rating Question danbeall HVAC 6 11-04-2010 08:32 PM
Low Well Pressure, Submersible Well Pump, Help Please! tpolk Plumbing 7 11-13-2009 06:13 PM
pressure treated lumber - Painting Question slim one Painting 1 05-05-2009 06:35 PM
Bryant Pilot Burner modemjim HVAC 2 12-13-2008 01:17 PM
