Gas Pack Problems - HVAC - DIY Chatroom Home Improvement Forum
Old 02-13-2010, 09:36 AM   #1
Gas Pack Problems
I have a 3.5 ton gas pack installed in about 1993. The temperature does not stay constant in all rooms. Thermostat set on 70 but main open living/kitchen/dining reading about 66. Large family room reading 65. House is long ranch about 76' straight. Had contractor out and he checked freon, blower, cleaned coils, changed and cleaned filters, changed the confirguration of main duct work and trunk lines. The air is not blowing out of the vents very hard (more of a trickle). It also does not feel very hot to me, however, when he puts his thermometer into the vent it is reading about 90+ degrees. I am tired of being cold. Any suggestions as to what else it could be before I buy a whole new unit. My house is 2,150 sf.
GinaTH is offline   Reply With Quote
Old 02-13-2010, 03:17 PM   #2
An old Tradesmen
Rewards Points: 8,154
Only 90F from a gas pack?
Sounds like you duct isn't insulated. Or something is wrong with the burners.
Without more info can't tell you much about your air flow problem. What size is your return grille and duct work?
Problems with Square D Subpanel bltglt507 Electrical 16 12-04-2009 08:44 PM
Help with gas pack trunk sizing justinNC HVAC 3 10-31-2009 08:38 PM
How to diagnose problems with wall kahlan General DIY Discussions 5 10-22-2008 09:18 AM
Elec short causing A/C problems or A/C problems causing elec problems? Marlon Electrical 2 06-25-2008 02:04 PM
Are you having ice problems? Grumpy Roofing/Siding 27 02-17-2008 03:51 PM
