Gas Logs Issues - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 08-21-2012, 07:43 AM   #16
Rewards Points: 14
Originally Posted by how View Post
With the system and wiring you describe..
you have multiple faults happening..
Continuity through a circuit when it shouldn't be there and not enough continuity through a circuit when it should. You need a pro checking the dcmv output on the gas valve/ power pile and manual switch/receiver circuit to tell what's what.
I have a multimeter. Is that check something I could do?
NJPhily is offline   Reply With Quote
Old 08-21-2012, 11:59 AM   #17
how
Rewards Points: 1,104
Normally yes, but since you seem to have more than one fault going on, the interpretation of the results would be questionable. You could try disconnecting just the two wires from the receiver to the manual switch to see if the manual part of the fire place will turn it on & off. If it works OK..measure the dcmv of the power pile leads at the gas valve with the manual switch off, and then on. It should be over 100 and 250 dcmv respectively.
how is offline   Reply With Quote
Old 08-21-2012, 02:09 PM   #18
raylo32's Avatar
Rewards Points: 1,252
Differrent brand than mine so maybe not applicable but my receiver is actually built into the 3-position manual switch (off-on-remote), and that is where the receiver batteries live. If you haven't looked there you might want to pull the cover plate off and have a peek.
Live long and prosper.
raylo32 is offline   Reply With Quote
Old 10-11-2012, 09:12 AM   #19
Rewards Points: 14
Don't know what to think. I turned on the logs for the season and it's now working fine.Left scratching my head.
temperature and pressure issues jpa137 Plumbing 7 04-04-2012 09:48 PM
Attaching Joist to Logs Earnie Building & Construction 6 09-19-2011 03:27 PM
House settling issues gmvshort Building & Construction 3 02-22-2011 06:26 AM
Spray foam - code issues? upinsmoke Building & Construction 1 05-10-2010 07:47 PM
