Gas Logs - HVAC - DIY Chatroom Home Improvement Forum
Old 11-06-2010, 10:24 AM   #1
Gas Logs
My pilot light will not stay lit. When I release the pilot button it flame goes out and the burner never lits.
I have vaccumed the pilot light area.
I have clear with a wire the first two or three inches of the line.
GAnge is offline   Reply With Quote
Old 11-06-2010, 06:26 PM   #2
HVAC / Plumbing
You may have dust in the pilot air intake. Use air to blow out this area
kenmac is offline   Reply With Quote
Old 11-06-2010, 07:14 PM   #3
GC/Master Plumber/Mech
Rewards Points: 560
Sounds like a thermocouple as gone bad
John Wayne once said "Life is tough and it is even tougher if you are stupid"
Tempstar and Trane Dealer
Old 11-06-2010, 08:05 PM   #4
HVAC / Plumbing
It's Possible. I get calls on these seems like every winter. Dust gets in the small air hole at the pilot assy. and causes the pilot to burn a little yellow. Just enough yellow to cause the pilot to lift a little off the tip of the t. couple. Then the safety drops out
Old 11-06-2010, 08:09 PM   #5
Rewards Points: 560
good point Ken
Gas Logs GAnge Appliances 2 11-08-2010 08:44 PM
Logs landing on a septic tank gma2rjc General DIY Discussions 3 06-05-2010 06:10 PM
New Ventless Gas logs in an old chimney. Now how to block the chimney? keyser soze HVAC 4 03-02-2008 06:07 PM
Chimeny Liner Tbuddy General DIY Discussions 7 05-03-2006 12:27 PM
