Old 01-12-2010, 11:34 PM   #1
Gas Line Question
OK: Here's the deal. My brother in law gave my wife and I a washer and dryer. The issue was that we have to run a gas line to the new appliances. The gas line that is in my house already is 1/2 inch but the tools he has only applies to 1/4 line. So he's going to run the 1/4 line to the appliances.
My question is: Is this dangerous? Is it dangerous to downsize the size of the line? I figure it isn't because it's going to a regulator and the regulator will take care of the flow but....
Yeah, any help?
jasonresno is offline   Reply With Quote
Old 01-12-2010, 11:44 PM   #2
Gas Line Question
what size line does the dryer take?
brewmastr is offline   Reply With Quote
Old 01-12-2010, 11:46 PM   #3
Gas Line Question
I believe it takes 1/4 inch.
Old 01-12-2010, 11:47 PM   #4
Gas Line Question
well if it take 1/4 inch it needs to be downsized anyhow. so you should be fine as far as i am aware.
Old 01-13-2010, 07:55 AM   #5
Gas Line Question
Reread the manual to be sure and if it takes 1/2 inch I would be leary depending what else is drawing from the 1/2 in line.
SULTINI is offline   Reply With Quote
Old 01-13-2010, 09:01 AM   #6
Master General ReEngineer
Bondo's Avatar
Gas Line Question
Ayuh,... Every dryer I've ever seen needs Atleast a 3/8" line, with 1/2" being better...
Downsizing the line to 1/4", will lead to inferior performance...
It don't cost That much for the Proper tools to do the job,... Right...
Old 01-13-2010, 11:05 AM   #7
Gas Line Question
you need to do a calc.to figure out how many btus that 1/2 is feeding already 1/2 for a whole house is mighty small and is probably maxed out already. you may have to run it back to where the largest pipe is now usually 3/4 or 1
' at the meter
nat gas or propane? make sure dryer is configued for the type of gas youre using or youll have probs
kennzz05 is offline   Reply With Quote
Old 01-13-2010, 02:53 PM   #8
An old Tradesmen
Gas Line Question
You may need to run a larger line to the dryers area. And then run the 3/8" line.
A 1/2" main gas line doesn't carry a lot of gas.
Old 01-13-2010, 06:57 PM   #9
Gas Line Question
Thanks for the replies so far guys.
My house (an older single story home) is about 1200 sq ft with natural gas. Not big at all. he wants to T off of the gas line, run it about 15 feet through my attic, and pull it down to the dryer. I'll let him know what you guys said but...is there any actual physical danger in downsizing the gas line? I don't want gas building up and my house exploding (I'm bein' dramatic, but you get my point).
Thanks again.
Old 01-13-2010, 09:24 PM   #10
An old Tradesmen
Gas Line Question
Yes. Can cause CO production from the water heater and furnace beside the dryer itself.
Old 01-14-2010, 05:18 AM   #11
Gas Line Question
Get a gas contractor to do this under permit, because if something goes wrong your ass is covered. Sizing gas is relatively easy, but if you don't know what you are doing it will result in trouble (not blow yourself up, but maybe "go to sleep and never wake up" kind of trouble). As for 1/2" and 1/4" lines? Not enough info! What material? What pressure is the meter supplying? How long is the longest run? What is the total demand? Even with all of these questions answered I still couldn't give you a definitive answer to what you need.
hvac benny is offline   Reply With Quote
Natural gas line????? figs Plumbing 1 06-14-2009 02:13 PM
Question About Grout Line Size Greytguy Flooring 6 01-21-2009 01:05 PM
Service line from house to garage.... question Todd-sta Electrical 24 11-10-2008 01:23 PM
how to run fridge water line under kitchen floor? travishume Plumbing 23 09-26-2006 08:51 AM
Installing exterior faucet to washer line? skellies Plumbing 3 06-18-2006 09:19 PM
