Gas Line Question. - HVAC - DIY Chatroom Home Improvement Forum
Old 10-05-2012, 11:59 AM   #1
Rewards Points: 164
So I currently have a 1 inch line that has two 1/2 lines t off of it for the furnace and the water heater. Now I've bought a gas stove, I've run gas line before so I'm not concerned about the mechanical part if it, but the supply part. Easiest way for me to do this is to replace the elbow that feeds the water heater with a t and continue that line over to the stove. Is a 1/2 inch line sufficient to run a water heater and a stove?
ryan50hrl is offline   Reply With Quote
Old 10-05-2012, 12:05 PM   #2
Rewards Points: 6,652
I have a 3/4 feeding my stove, 1/2 feeding my water heater.
Old 10-05-2012, 12:12 PM   #3
Rewards Points: 164
Well I'm pretty sure that I'm only required to run half inch to the stove, but will 1/2 inch linefeed both?
Old 10-05-2012, 12:15 PM   #4
I would make a manifold with three T's. One for the furnace, one for the water heater, one for the stove. Place a Ball valve at the T's, so that you can shut each one off respectively. Especially makes it easier for the stove, so that you do not have to move it.
Old 10-05-2012, 12:46 PM   #5
raylo32's Avatar
Rewards Points: 1,284
I agree with Greg. Best to have one line for each. I have a 1/2" line to my stove (I think ~50,000 BTUH), a 1/2" line to my water heater (40,000 BTUH) and a 3/4" line to my furnace (80,000 BTUH) all off separate t's on a 1 1/2" manifold. I seriously doubt that connecting 2 loads of the size you are suggesting to a single 1/2" line would meet code... even though it would probably "work" since it is unlikely that your water heater would come on at the same time when you have every single burner going on the stove/oven.
Live long and prosper.
raylo32 is offline   Reply With Quote
Old 10-05-2012, 01:50 PM   #6
Anyone telling you what size to use is simply guessing and giving you possibly dangerous advice. To size a gas line, you need to know the pressure, the lengths and the loads. Draw the system out, then use the gas line sizing tables applicable to your area (B149 in Canada). Then, and only then, you will have your answer. An undersized line could have severe repercussions, both to your appliances' life and your own.
hvac benny is offline   Reply With Quote
The Following User Says Thank You to hvac benny For This Useful Post:
ben's plumbing (10-05-2012)
Old 10-05-2012, 03:38 PM   #7
Rewards Points: 616
and no gas permit means home insurance issues.... please get permit
carmon is offline   Reply With Quote
Old 10-05-2012, 05:45 PM   #8
Rewards Points: 582
water heater is 35,000 or 40,000 btu....how many btu is stove.... how long of run is it ... then we can go from there...ben sr
Old 10-05-2012, 06:02 PM   #9
Rewards Points: 164
Water heater Is 40k and three feet from the 1 inch line, range is 71.2k and is 15 feet from water heater.
Old 10-05-2012, 06:47 PM   #10
Rewards Points: 616
you need the total load longest run and distance to each appliance... I can size it in 2 seconds for you but canadian codes may differ from yours...
Old 10-05-2012, 06:50 PM   #11
An old Tradesmen
Rewards Points: 7,356
I'd change the tee at the 1" to a 3/4" tee. Then run 3/4" to the water heaters current ell and reduce to 1/2" to teh water heater, and continue with 3/4" to the stop valve your gonna use for the stove. that way, the water heater shouldn't have any effect on the stove.
The Following User Says Thank You to beenthere For This Useful Post:
Old 10-05-2012, 06:50 PM   #12
You need to measure the gas lines back to the meter (provided there are no regulators in between). The longest measured run will give you the code zone, and from there you can determine pipe capacity once you know the pressure (probably 7" w.c.).When you say 3' away, do you mean 3' of pipe, or physically 3' from the 1" gas line?
Old 10-05-2012, 07:09 PM   #13
Rewards Points: 164
Physically 3 feet. And gas line all the way in is 1 inch.
Old 10-05-2012, 07:11 PM   #14
Rewards Points: 616
whats the longest run and total load...then we can help
Old 10-05-2012, 07:20 PM   #15
Originally Posted by ryan50hrl
Physically 3 feet.
Thats what i thought. We'll need the length of the pipes.
Nevada: Gas line code question bent240lv Plumbing 0 10-04-2011 02:21 PM
Sewer main line repair question dgeorge Plumbing 4 08-10-2011 07:21 AM
Capacity loss with line size Einride HVAC 1 06-29-2009 03:10 PM
GFCI question: can line and load wires be run inside the same conduit? thegonagle Electrical 32 04-16-2009 06:07 PM
Question about protecting CSST gas line Racer Plumbing 9 01-10-2007 03:19 PM
