Gas Hot Water Burner Wont Ignite On Its Own - HVAC - DIY Chatroom Home Improvement Forum
Old 12-12-2010, 08:10 PM   #1
gas hot water burner wont ignite on its own
My hot water started running out quickly. Then it was taking 2-3 days to warm up but wasn't even getting ver hot. I have found that the burner only seems to kick on if I turn the control knob all the way in the on position until the gas is coming out and hold it there for 30 seconds or more. I get good flames then and the water heats up.. i can't replace it right now but want to make sure its safe. And is there anything I can do to fix it cheaply?
yoopgirl is offline   Reply With Quote
Old 12-12-2010, 08:18 PM   #2
An old Tradesmen
Rewards Points: 6,540
Just replace it. They are not serviceable.
Water Inside/Around American Standard Furnace michrob HVAC 8 12-08-2011 04:51 PM
Lost Hot water pressure brile Plumbing 11 11-28-2010 03:59 PM
Leaking water line needs new water regulator? huynh Plumbing 16 11-04-2010 12:32 PM
low hot water pressure angus242 Plumbing 10 01-08-2009 12:41 PM
Testing 12 year old hot water expansion tank? DJfixer Plumbing 2 01-01-2009 09:09 AM
