Gas Hot Water Boiler Keeps Shutting Down - HVAC - DIY Chatroom Home Improvement Forum
Old 04-14-2009, 08:44 AM   #1
Gas Hot water boiler keeps shutting down
My 12 year old gas burning hot water boiler every couple of days decides to shut down and in the morning when I need hot water for a shower I have to go down and hit the reset button. I am then fine until the next morning or two mornings, We have had repairman there three times and they cannot find anything besides replacing a fuse that was burnt and adjusting the temp down from 200 to 180 degrees. We had a new expansion tank put in 6 months ago. It is a Laars Mighty Term and connection piping is mostly copper.
brownstonenyc is offline   Reply With Quote
Old 04-14-2009, 09:32 AM   #2
HVAC / Plumbing
What brand name ?
kenmac is offline   Reply With Quote
Old 04-14-2009, 09:37 AM   #3
Laars Mighty Therm.
Old 04-14-2009, 09:52 AM   #4
HVAC / Plumbing
Could be shutting down on high temp.can you check any of the linits / safetys ?
Old 04-14-2009, 09:55 AM   #5
One of the plumbers tried lowering the temps down from 200 to 180. What do you mean linits/sa
Old 04-14-2009, 11:39 AM   #6
HVAC / Plumbing
It could be a high water temp. Limit causing this or any other safety devices that mabe installed on the unit.if you can catch it when the problem occurs you should be able to determine what's causing it.
Old 04-14-2009, 12:29 PM   #7
Hvac Pro
yuri's Avatar
Rewards Points: 2,238
Post the model#. Does it have a spark ignition or a HSI glow plug to light the gas?
Low hot water pressure crebive Plumbing 38 02-26-2013 12:26 AM
Hot water boiler furnace-insufficient heat Nashman HVAC 2 11-06-2011 06:15 PM
electric oil boiler? for hot water? jamesdart Plumbing 2 01-13-2008 08:06 PM
No Expansion Tank for Water Heater vasanvasan Plumbing 4 12-13-2007 11:16 PM
Hot Water boiler furnace-shut off/on Nashman HVAC 1 01-14-2005 11:54 AM
