-   -   Gas Hot water boiler keeps shutting down (http://www.diychatroom.com/f17/gas-hot-water-boiler-keeps-shutting-down-42419/)
brownstonenyc 04-14-2009 08:44 AM
My 12 year old gas burning hot water boiler every couple of days decides to shut down and in the morning when I need hot water for a shower I have to go down and hit the reset button. I am then fine until the next morning or two mornings, We have had repairman there three times and they cannot find anything besides replacing a fuse that was burnt and adjusting the temp down from 200 to 180 degrees. We had a new expansion tank put in 6 months ago. It is a Laars Mighty Term and connection piping is mostly copper.
kenmac 04-14-2009 09:32 AM
What brand name ?
brownstonenyc 04-14-2009 09:37 AM
Laars Mighty Therm.
kenmac 04-14-2009 09:52 AM
Could be shutting down on high temp.can you check any of the linits / safetys ?
brownstonenyc 04-14-2009 09:55 AM
One of the plumbers tried lowering the temps down from 200 to 180. What do you mean linits/sa
kenmac 04-14-2009 11:39 AM
It could be a high water temp. Limit causing this or any other safety devices that mabe installed on the unit.if you can catch it when the problem occurs you should be able to determine what's causing it.
yuri 04-14-2009 12:29 PM
Post the model#. Does it have a spark ignition or a HSI glow plug to light the gas?
