Old 12-03-2008, 07:40 PM   #16
hvaclover's Avatar
Gas heater won't kick off?
You can order off your manual.
If it stuck on(?) it will do it again.
And that valve won't be cheap.
Just slow, not stupid.
hvaclover is offline   Reply With Quote
Old 12-04-2008, 11:26 AM   #17
Check the ground. Make sure the pilot orafice is clean with a small pin being sure to not enlarge the opening. Flame sensor OK/Clean?
Stiking the valve may have jolted the ground back in contact?
Daltex is offline   Reply With Quote
Old 12-04-2008, 11:56 AM   #18
hvaclover's Avatar
Daltex, that is a Pizio Electric start. Just like a Bar B Que lighter. Does a ground apply to this type system?
Just curious...
Old 12-05-2008, 02:59 PM   #19
not sure but the valve is malfuctioning for sure.......
will search for prices.....model #646
part#301273-702
thxs for all the help.....happy hollidays
maelo_el_feo is offline   Reply With Quote
Old 12-06-2008, 04:21 AM   #20
An old Tradesmen
You semi hijacked the thread.
So some people are answering your questions, and others are thinking its an answer to the OP.
Old 12-06-2008, 09:44 AM   #21
hvaclover's Avatar
Yeah . You hijacked the thread and completely left the OP in the dust.
I thought we were still advising the OP.
Bad form maleo el feo.
Electric Kick Heater for Bathroom meth HVAC 5 01-13-2009 10:31 AM
Wiring to a water heater bvsmith_1974 Electrical 3 09-03-2008 04:32 AM
Water heater problem bear1957 Plumbing 23 11-01-2007 04:53 PM
Baseboard heater Help! jweinstock Electrical 6 10-28-2006 05:01 PM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 11:31 AM
