Gas Heater Won't Kick Off? - HVAC - DIY Chatroom Home Improvement Forum
Old 12-01-2008, 01:49 PM   #1
Gas heater won't kick off?
We are about the take posession of a house that has a natrual gas heater out in a room attached to the garage.
Here is the manual
http://12.153.20.72/tech/manuals/103568-01B.pdf
I'm not familar with gas heat such as this...
As far as i'm aware the heater stays on constantly and even on low the room is about 90 degrees right now.
Doesn't this thing have some kind of thermostat to shut the gas off at a reasonable temp And then kick it back on when the room cools?
I could have swore when we were looking at the house this heater was kicking on and off by it's self.
Chevyscrounger is offline   Reply With Quote
Old 12-01-2008, 06:19 PM   #2
An old Tradesmen
Rewards Points: 6,548
The control just regulates how much gas it burns. Not the temp of the room.
Old 12-02-2008, 08:42 AM   #3
So once this model is lit it runs constantly?
Old 12-02-2008, 08:57 AM   #4
An old Tradesmen
Pretty much so.
Your suppose to set it to off, when you don't want any heat.
One of those things they don't tell you before you buy them.
The knob can only regulate how much gas it burns per hour.
With adjustment from low to high having technically an infinite amount of vairance.
It is not made, or approved as a sole source of heat for a room or house. So its not required to have a thermostat to regulate it.
Old 12-02-2008, 01:14 PM   #5
I thought the previous owners had it going to keep the pipes in that bathroom from freezing.
Here are pics. (Keep in mind this is in a detached garage)
The room it heats. you can see the heater on the left
http://img.photobucket.com/albums/v6...e/img_4880.jpg
Snd the bathroom..
http://img.photobucket.com/albums/v6...e/img_4879.jpg
Do you guys think if i just turned off the gas heater I'd have to worry about the pipes in the bathroom freezing up?
Do you think the hot water heater would put off enough heat to keep it from freezing?
Old 12-02-2008, 02:54 PM   #6
An old Tradesmen
Hard to say.
Better to use the gas, then repair broken pipes, and water damage.
Old 12-02-2008, 04:12 PM   #7
Rewards Points: 109
Why don't you turn the gas all the way down and see what the temp is. If it's still hot (80* +) then you can consider getting a portable electric heater with a thermostat that will keep it cool but not cold enough to freeze. Just a thought. The cost of the gas may be less than the electricity for even a small heater.
Daltex is offline   Reply With Quote
Old 12-02-2008, 04:40 PM   #8
It's turned down as low as it will go and it's 90 degrees in there.
I will probably stick a little electric heater in there for the winter.
Old 12-02-2008, 04:56 PM   #9
Why not just replace the defective component?
hvaclover is offline   Reply With Quote
Old 12-02-2008, 06:03 PM   #10
According to the other replys to this topic I don't think there is a defective component.
Old 12-02-2008, 06:27 PM   #11
is this Dale Earnhardts hair salon??? between furnace and water heater and hair products you better have good ventilation
burr is offline   Reply With Quote
Old 12-03-2008, 08:54 AM   #12
LOL Those are pictures from the Realty site. The old gal that previously owned the house and ran the salon must have been a HUGE Earnhardt fan. There were boxes and boxes of races on VHS tapes. She took all the pictures and stuff with her. I used to be a fan when he was around,but haven't seen a race in years and could care less now. :P
The gas heater is vented correctly like that manual shows.
We're probably just going to convert the room to a spare bedroom/gameroom
Old 12-03-2008, 12:05 PM   #13
hey guys new here, I have a carrier 58ss forced air furnace and it is not puttin out warm air. It blows air but each time it tries to ignite it lights for a few seconds then goes out and it keep doing that but never light the blower just keeps going. Does anyone have an idea of what might be causing it not to ignite ?
maelo_el_feo is offline   Reply With Quote
Old 12-03-2008, 03:07 PM   #14
You change your filter recently? That's one possibility.
Or your flame sensor is dirty.
Old 12-03-2008, 07:27 PM   #15
I think is the gas valve because i hit it with screwdriver and took of......
any ideas how much will it cost me for new gas valve????
thxs for all the help!!!!
Electric Kick Heater for Bathroom meth HVAC 5 01-13-2009 10:31 AM
Wiring to a water heater bvsmith_1974 Electrical 3 09-03-2008 04:32 AM
Water heater problem bear1957 Plumbing 23 11-01-2007 04:53 PM
Baseboard heater Help! jweinstock Electrical 6 10-28-2006 05:01 PM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 11:31 AM
