Old 11-04-2006, 12:03 PM   #1
gas heater trouble
Hello All,
I am having some trouble with my central heating unit.
When I turn it on and set my thermostat, I hear it start up and
the gas lights. But it burns for like 30 seconds then clicks off, this reapeats until I switch the unit off. Now it does not do this all the time
but the majority of the time it does. Any ideas?
thanks
toughy is offline   Reply With Quote
Old 11-04-2006, 01:12 PM   #2
Thoroughbred Mopar Man
gas heater trouble
Hi toughy
It sounds like you have a new enough furnace to have a flame sensor. The flame sensor is a metal rod in front of the burner that is opposite of the ignition source, possible ignition sources are hot surface, direct spark, intermittent pilot. If the unit uses a pilot the flame sensor could be located in the pilot burner. Look for a rod that is about 1/8"-3/16", it should have a single wire coming off from it. The wire could be yellow or white and some manufacturers use a orange one. Once you verify what you are dealing with, unplug or shut power off to furnace, remove the rod from the furnace, use a wire brush and clean very well. ( use wire brush only, DO NOT USE SANDPAPER OR SANDCLOTH ). Reinstall the flame sensor, turn power back on to furnace, unit should operate properly. If it does not stop the problem it could be ignition system is failing. Not sure what type or model furnace you are working with, but if this does not work if you can give me the information, I can walk you through it.
Good luck
Rusty
#CARRIERMAN is offline   Reply With Quote
Old 11-04-2006, 02:55 PM   #3
gas heater trouble
Hey,
Thanks a lot!
I will give this a try and see where it gets me.
The unit I have is a mobile home unit made by intertheme.
I think it is from the later 90's. It works great when it is working!
Thanks Again,
I'll keep you posted
-rowdy
Installing a tankless water heater ? bdalekid Plumbing 3 02-26-2007 08:26 PM
Chimney Liner for Water Heater mruggeri001 HVAC 6 01-10-2007 07:08 AM
Wiring electric heater in bathroom PatSea Electrical 5 01-06-2007 10:40 PM
Baseboard heater Help! jweinstock Electrical 6 10-28-2006 05:01 PM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 11:31 AM
