Gas Heater Problem - Temperature Differential - HVAC - DIY Chatroom Home Improvement Forum
Old 12-07-2011, 02:41 PM   #1
I'm having trouble with wide temp differentials in the house, especially in the master bedroom. At different times, very cold, others very hot. Didn't experience these wide differentials during the very hot Summer using air conditioning.
Details..hopefully this covers it:
New Home in North Texas
4600 Sq Ft
One Story
Zoned Gas Furnaces - two units
House insulated very well
There are only two large ducted returns in the house. They are in the ceiling, at about 10 ft level. Somewhat centrally located. Ceilings in some locations are vaulted up to around 14 ft.
Thermostats are located near the returns. They appear to be accurate and functioning properly.
One return / thermostat is located just outside master bedroom door. There is about 1000 Sq Ft of living space through master, into bath and closet. Lots of air pressure at the master door.
Nights start off on cold but around 3-4 am get very hot.
I have tried:
Matching the thermostat temps / schedules
Raising / lowering other thermostat
Adjusting vents
Leaving bedroom door open (problematic because of dogs, etc)
Considering:
Hiring professional air balance service
Installing pass-thru vent above master bedroom door
Installing an additional return in the master
Installing thermostat w/ remote sensor(s)
Not sure if this falls under warranty. Should I go back at the builder with this complaint or it it relatively common?
Thanks for any guidance.
jejagua is offline   Reply With Quote
Old 12-07-2011, 05:34 PM   #2
biggles's Avatar
do you have programmmable stats check the times and temperatures and time changes if so....set the temps all the same to eliminate the changes see if it runs more consistant sleep to wake are yu set in auto for system or heat on the stat...just try heat on system fan auto in the problem area
Old 12-07-2011, 05:56 PM   #3
the problem is the returns......centraly located returns are a very very bad idea.....
harleyrider is offline   Reply With Quote
Old 12-07-2011, 06:02 PM   #4
There should be at least a 1 year labor warranty on new construction. Call the HVAC company that installed the systems and let them figure it out.
window condensation kmpittman Windows and Doors 4 11-29-2011 09:10 AM
Never Seen This Before! Water Heater Problem Please Help JOSH76 Plumbing 5 02-14-2011 08:13 AM
Water Heater Problem mdong HVAC 19 11-29-2009 10:53 AM
Electric Baseboard Heater Problem goombie Electrical 9 12-23-2008 12:13 AM
Electric Water Heater Problem mw2727 Plumbing 4 08-21-2008 01:51 PM
