Gas Heater Ignitor Won't "glow" - HVAC - DIY Chatroom Home Improvement Forum
Old 10-13-2012, 07:08 PM   #1
Rewards Points: 79
Gas Heater Ignitor won't "glow"
Hello!
I have a gas central air heater/AC that is acting up. We turned on the heat the other day but it wouldn't light =/
Every year I have to clean the flame sensor and all is well, unfortunately the ignitor isn't even glowing this time.
I figure I may have a cracked ignitor, and want to take a multimeter to it to confirm, but am not sure exactly "where" to test. Would I just put it on the positive and negative cables coming from the computer?
thanks!
llmercll is offline   Reply With Quote
Old 10-13-2012, 07:23 PM   #2
biggles's Avatar
set the meter to read OHMs with the power off and the wires from the ignitor off the control module should read a dead short or resistance if the meter sits at 00.0 the coil is broken/craked.then with the wires off the board call heat and read the terminals you pulled the wires off to read the voltage signal...to make sure the board is sending a call.
Old 10-13-2012, 08:06 PM   #3
Rewards Points: 79
Thanks for the reply,
I pulled the ignitor and sure enough it has a crack, also showing "infinite" resistance when I check ohms
I'd like to make sure my wires are working properly before ordering my replacement ignitor and calling it a day though, Should I just turn the heater on and check the voltage of the two wires that go into the ignitor? (sounds dangerous)
thanks!
Old 10-14-2012, 01:36 AM   #4
how
Rewards Points: 1,104
Just make sure that the Hot surface Igniter is unpluged and you are just testing the wires supplying it with power. The point is to do it in such a way that those live feed wire ends have no way of contacting each other or any electrically conductive surface. Also make sure that your meter probe ends don't cross and connect with each other during your measurement test.
Tell us the make and model of your furnace. Not all furnaces have igniters operating on 120V.
But..
If that igniter is cracked, you already have your reason why it's not working.
how is offline   Reply With Quote
Old 10-17-2012, 03:50 PM   #5
Rewards Points: 79
Thanks everyone, replacing the ignitor did the trick =)
Old 11-03-2012, 07:29 AM   #6
Rewards Points: 79
Ahh not even two weeks and the new ignitor has a crack in it =/
I've got a replacement on the way. Any ideas why it burned out so quickly? I definitely did not touch the ceramic part.
thanks!
Old 11-03-2012, 07:53 AM   #7
An old Tradesmen
Rewards Points: 8,170
Did you put a 24 volt HSI on a 120 volt system.
Old 11-03-2012, 02:13 PM   #8
Hvac Pro
yuri's Avatar
Rewards Points: 386
need to know the model and age of furnace. post a pic of the burners. not all igniters use 120 volts and low voltage can burn them out.
Old 11-06-2012, 07:33 AM   #9
Rewards Points: 79
Sorry for the late reply, and thank you for the comments.
I believe I am using the right voltage. The unit I replaced had the same model number as one that's been in there a few years.
http://www.pexsupply.com/Robertshaw-...71W-11645000-p
Here are some pictures I took
It looks like the furnace is a GMP and is about 20 years old.
I didn't notice any polarity markings on the HSI, is it possible I may have wired it wrong? Other than that I'm thinking maybe the area around it was dirty and some dirt got on the ceramic, or possibly it was just defective?
I've got my replacement coming today and don't want to mess up, it's been really cold here in NY =p
thanks!
Old 11-06-2012, 01:07 PM   #10
20 year old gmp is pretty much guaranteed to have a cracked heat exchanger. Rough ignitions will crack those fragile ignitors quickly.
The Following 3 Users Say Thank You to Marty S. For This Useful Post:
beenthere (11-06-2012), ben's plumbing (11-06-2012), llmercll (11-06-2012)
Old 11-06-2012, 04:56 PM   #11
Rewards Points: 79
Got the new HSI, installed it with no troubles, furnace is working now. But for how long =/
How can I check if I have a cracked heat exchanger?
thanks!
Old 11-06-2012, 05:09 PM   #12
An old Tradesmen
One way is to watch the flames when it first starts, and keep watching them till the blower starts. Do they start jumping around. if so, good chance the heat exchanger is cracked.
The Following 2 Users Say Thank You to beenthere For This Useful Post:
Old 11-06-2012, 05:18 PM   #13
Rewards Points: 582
thanks!
as b t said watch flames after blower starts....but we use a camera..may still want to have a pro check it to be double safe...ben sr
The Following User Says Thank You to ben's plumbing For This Useful Post:
Old 11-06-2012, 05:24 PM   #14
Remove the blower and crawl up in there with a bright flashlight. Often times on those there will be rings sitting on top of the blower assembly. They are what's supposed to hold the heat exchanger together so finding one means the heat exchanger is shot and there will be no need to crawl in.
Old 11-06-2012, 05:38 PM   #15
Rewards Points: 79
Thanks a lot for the input. Fortunately the flame stays the same when burner starts, maybe it's a bit more "orange" but it's extremely subtle if anything. I'm also taking my CO detector around because now I'm worried haha. Everything seems good there though.
http://www.ehow.com/info_12207084_ca...r-failure.html
After reading this thread I did notice my furnace cycles quite a bit. It will come on for maybe 3 minutes, go off for 5, and repeat. I thought that was normal but I'm not so sure now. If the temp drops to 69 it will turn on until it hits 70. In the summertime my HVAC guy told me the AC's evaporator coil was clogged, causing my Freon pipes to freeze. He cleaned it up and it worked great after that, but could it be related?
I cant have this thing failing every 2 weeks =/
thanks!
water heater drip kdange1 Plumbing 6 10-29-2014 05:26 PM
Pilot on Williams millivolt wall heater goes out every 8 to 16 hours wornways HVAC 30 06-22-2011 03:29 PM
Min distance from baseboard hotwater heater capslock General DIY Discussions 2 05-25-2010 07:31 AM
Water heater problem bear1957 Plumbing 23 11-01-2007 03:53 PM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 10:31 AM
