Gas Heat To Rooms - HVAC - DIY Chatroom Home Improvement Forum
Old 01-19-2011, 01:40 PM   #1
gas heat to rooms
I have two rooms that used to be warm but now are cold even when the thermostat is set right
haroldgeorge is offline   Reply With Quote
Old 01-19-2011, 02:08 PM   #2
Experienced
Jackofall1's Avatar
You used to have, what happened, any changes?
what type of heating system?
Its tough to help anyone with that kind of information or the lack thereof
how does a controlled heat transfer work? Red Squirrel HVAC 8 09-25-2010 04:04 PM
Rheem Package Heat Pump Newbie03 HVAC 4 02-26-2010 06:32 PM
Urgent! House Cold, NO heat, pilot lit (Lennox) ThatGuy23 HVAC 15 02-05-2009 09:11 PM
How to test apartment Heat Pump tbrubes HVAC 7 02-04-2009 03:05 PM
Which diagram to use on Lenox Thermostat wiring setup? Heat Pump Lenox techs needed twilightcall HVAC 1 08-13-2008 11:49 AM
