Gas Furnance Over-firing, How Do I Correct? - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 09-16-2010, 08:48 PM   #16
Hvac Pro
yuri's Avatar
Rewards Points: 396
I would check it once a week for the first 2 months. That valve may still be faulty and wander out of range. 4" is the max I have seen and it may lose its adjustment on its own. I would be uncomfortable with what it is doing.
Old 09-16-2010, 08:54 PM   #17
Seasoned DIYer
Rewards Points: 150
I don't mess with gas stuff, but meter clocking method is good enough, right?
HVAC_NW is offline   Reply With Quote
Old 09-17-2010, 02:22 AM   #18
You should out of respect for our industry and the dignity of the PROs here drop the hvac from you screen name.
Hvac in your name misleads other diy posters in thinking you are a PRO. And yet they read this thread where you did not install your own furnace and didn't have the right tools to check the gas press. You make us look bad.
If you don't mess with gas you are no HVACer.
my 2 cents
clover
hvaclover is offline   Reply With Quote
Old 09-17-2010, 03:34 AM   #19
An old Tradesmen
Rewards Points: 8,194
If it was good enough. We wouldn't have combustion analyzers. Or check temp rise across heat exchangers.
Old 09-17-2010, 04:00 AM   #20
Seasoned DIYer
Rewards Points: 150
my 2 cents
clover
My registration date precedes yours by an entire year,son. It's what I happened to pick in 2007. I haven't logged in a while. I added a user title to clear any confusion and this is a DIY forum. You are not the one to tell me what my user name should be.
Old 09-17-2010, 04:19 AM   #21
An old Tradesmen
Your screen name, while confusing. Doesn't violate any for um rule I know of.
Old 09-17-2010, 05:35 AM   #22
Hvac Pro
yuri's Avatar
Rewards Points: 396
Meter clocking is okay but I would google U-tube manometer. Can make one yourself. Still best to get a Pro to check it but I am concerned you monitor it for awhile for safety. Working with gas is DANGEROUS and not recommended for DIYers but we can't stop people from doing it. I am sure electricians and car mechanics feel the same way about their trade.
In reality the manifold gas pressure will vary/modulate(+- .5"WC) on a high efficiency furnace. Vacuum thru the burner box/heat exchanger varies with outdoor temp and venting setup and sucks on the gas valve to alter the firing rate. Special procedure required and experience to know how to workaround and with that.
Old 09-17-2010, 11:28 AM   #23
It still does not make it right, but I won't make an issue of it.
You are right about making it confusing, though.
Old 09-17-2010, 02:54 PM   #24
HVAC / Plumbing
Don't forget SON . He was here a year b-4 you
kenmac is offline   Reply With Quote
Old 09-17-2010, 03:18 PM   #25
Originally Posted by kenmac View Post
Don't forget SON . He was here b-4 you
Yeah your right he was here before me..
But I can't be his SON! My Daddy wasn't afraid of gas and he knew how to repair.
Another reason he can't be my Daddy is because my Daddy would never have to ask for help on this site to make a repair.
Old 09-17-2010, 03:50 PM   #26
Seasoned DIYer
Rewards Points: 150
Anyways, dead-on calibration is impossible, because heating value changes from time to time due to variation in fuel composition, but here is the outcome. All measurements were taken based on time it takes to go through four cubic feet of nat. gas, then divided by four to improve accuracy.
Furnace rated input: 60,000BTU/hr
Before adjustment: 74,400BTU/hr
After adjustment: 58,400BTU/hr
Am I correct to assume that a few percent under fire is better than 25% over-fire?
There is no other gas appliances here, so it was the only thing burning gas. I don't see why energy content of fuel * rate of flow isn't enough to calculate BTU input.
Yuri: what's odd...
(I called service for this, didn't do it myself)
The valve pressure adjustment was not responding at all, for a while. It had to be unscrewed a lot before it became responsive at all, but at that point, it was responding perfectly. I'll check again when heating season comes in, but I'm not messing with gas line. I'm going to clock it, and if its skewed significantly, then I'm going to make a service call. I don't mess with gas pipes, period.
Old 09-17-2010, 04:11 PM   #27
What will give you an almost perfect burn is a combustion analyzer.
Old 09-17-2010, 06:19 PM   #28
Hvac Pro
yuri's Avatar
Rewards Points: 396
Turning the screw in increases the pressure but it sounds like it was bottomed/maxed out by a pizzed off worker. Meter clock it and you should be OK.
Tags
btus , furnace , heating values , natural gas , pressure regulator valve
Quatro Mba 080 NH2R furnance manual wolfden13 HVAC 1 02-10-2010 04:26 AM
Furnance question. diy4life Building & Construction 29 12-01-2009 05:39 PM
Furnance question satz HVAC 8 02-05-2009 07:44 AM
How do I pick the correct coaxial cable? fwmcbigfoot Home Theater 1 12-30-2008 09:45 AM
Furnance burner won't stay on. 2007ken HVAC 11 03-03-2008 11:29 PM
