Gas Furnace Won't Turn On - HVAC - DIY Chatroom Home Improvement Forum
Old 01-25-2014, 04:06 PM   #1
Gas Furnace won't turn on
I have carrier model 58STA/STX gas furnace. It's giving error code 34. I tried to clean buildup on flame sensor. It is trying to turn on, ignite glows to orange , but furnace doesn't start. Can you please help me troubleshoot?
rekhachandak is offline   Reply With Quote
Old 01-25-2014, 04:43 PM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 2,286
check if you have 24 volts across the 2 wires at the gas valve while the igniter is glowing. make sure your gas is ON to the house and any other gas appliances work. if the gas is on and you have 24 volts then the gas valve is bad ( or the burners are dirty and you need a Pro to check them and to find out if there is enough gas pressure) if no volts then the circuit board is bad. Removing and cleaning those particular burners and checking gas pressure etc is not DIY friendly or safe IMO.
The Following User Says Thank You to yuri For This Useful Post:
rekhachandak (01-25-2014)
Pilot light button on furnace won't turn whydonchathen HVAC 8 01-19-2015 10:40 AM
furnace doesn't turn on automatically akai HVAC 8 11-12-2012 02:45 PM
XL80 Trane Furnace Fan won't turn on jenlou HVAC 4 01-26-2012 05:59 PM
Comfortmaker furnace won't turn on steelframe8459 HVAC 36 11-30-2011 03:22 PM
Furnace w Cooling unit wont turn off Klatimer HVAC 2 09-19-2008 08:35 PM
