Gas furnace won't fire
Hi Peter Weber
Shut the power off to your furnace. Remove the burners completely from the furnace. Use a wire brush and clean them extremly well on the end the flames come out of. You may need to use a knife of some sort or a small tipped flat screw driver to clean the slotted portion. Use compressed air and blow all of the loose debris out of them after you wire brush them. Reinstall the burners and power the furnace back up. Let me know if this does not do the trick, you could have gas pressure problems. Give the burners a try first.
Good luck
Rusty
Character is doing the right thing even when no one is looking. Intelligence is understanding and practicing the meaning of character.
