Gas Furnace Wiring - HVAC - DIY Chatroom Home Improvement Forum
Old 05-09-2013, 06:47 PM   #1
Gas furnace wiring
I have a older gas furnace with a Robertshaw 720 series gas valve that is new. I am wondering if anyone can tell me how to wire this. There is a thermostat, transformer, high limit, blower motor and the valve. The valve has three wire terminals, 1 (to transformer), 2 (to thermostat) and the third is only labeled #3. Attached is a photo.
booboo is offline   Reply With Quote
Old 05-09-2013, 07:13 PM   #2
how
Rewards Points: 1,104
I'd say first
show us another photo after you've removed that old redundant reg and the manual pilot shut off fitting before the new gas valve and have moved the pilot tube over to the new valve.
There are a few different ways of wiring this valve using either two or three connections.
how is offline   Reply With Quote
The Following User Says Thank You to how For This Useful Post:
ben's plumbing (05-09-2013)
Old 05-10-2013, 08:09 PM   #3
Originally Posted by how View Post
I'd say first
OK, got new photos today.
Old 05-10-2013, 09:26 PM   #4
FClef's Avatar
Rewards Points: 160
In your first new picture, please tell me that there is a drip leg or sediment trap in that gas line. If there isn't one, there should be. I know this is a wiring question, but the red flags went up when I saw that picture.
FClef is offline   Reply With Quote
Old 05-10-2013, 09:47 PM   #5
Not sure they are required here. I almost never see them and I am deal with hundreds of homes like this one every year. Adding one is not a big deal, just not sure it is required. I will look into it. Even if it is not required can you give me a good reason why I should put one in?
Old 05-11-2013, 02:20 AM   #6
how
Drip legs catch the rust, scale, moisture and old pipe cutting oil that can come through the piping that can trash a new valve.
Your new photos show that....
Your upper limit & fan control are used parts from a different furnace.
The wiring is mostly adhoc non stock.
You have drip lines down the face of the furnace.
Your gas valve is miss wired.
I'd confirm that the heat exchanger is intact before going further.
But...
I for one do not feel comfortable advising you how to get this unit running as I see it now.
FClef (05-11-2013)
Old 05-11-2013, 04:29 AM   #7
FClef's Avatar
Rewards Points: 160
But...
Good advice. Inspect that heat exchanger well. Units that old can have cracks and that is never a good thing.
As far as the drip leg is concerned, it is good safety practice to have one whether they are required or not. If sediment travels through the pipe and gets lodged in the gas valve it can cause an explosion.
Old 05-11-2013, 10:02 AM   #8
OK, I will install a drip line. The furnace just needs to run for an appraiser. We are going to be replacing it before winter. We just can't get a loan without it running. We inspected the heat exchanger and it is in good condition with no cracks.
Old 05-13-2013, 04:32 PM   #9
Anyone willing to help?
Old 05-13-2013, 05:43 PM   #10
as seen on tv
Rewards Points: 150
Simple series circuit one wire from xmfr to limit from limt to valve out of valve to tstat then out of tstat to other side of xmfr. The other camstat is line voltage with a heater not in the control circuit
qbert is offline   Reply With Quote
Old 05-13-2013, 06:18 PM   #11
Roofmaster
Rewards Points: 2,210
Do you mean an appraiser to appraise your house??? They have to see if your furnace works to appraise your house??? I have never heard of such a thing. Where do they do this?
Old 05-13-2013, 06:54 PM   #12
We are purchasing the home. Lenders require the home to be habitable so heating and cooling needs to be working. The seller is out of state and is not able to make repairs so we are stuck with it. The furnace just needs to fire once for the appraiser. We are planning on replacing it and the evap cooler with a new heat pump after we own the home.
Old 05-23-2013, 04:13 PM   #13
This worked. Thanks for the help.
Natural Gas Cost For Furnace 1 Hour Run Time hammerlane HVAC 25 01-14-2015 02:13 PM
Brand New Concord Furnace Doesn't Work In Cold Weather LeighC HVAC 21 01-07-2013 08:48 PM
Day & Night furnace wiring JMattero HVAC 9 10-16-2012 10:35 PM
Water Inside/Around American Standard Furnace michrob HVAC 8 12-08-2011 03:51 PM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 01:55 PM
