Gas Furnace Will Not Stay Lit... - HVAC - DIY Chatroom Home Improvement Forum
Old 10-05-2010, 09:35 AM   #1
Gas Furnace will not stay lit...
Hi all. I'm not sure exactly what model of furnace I own (wasn't smart enough to check it first), but maybe you can still help me.
When the thermostat is turned to "heat" and the furnace is supposed to turn on, things start out ok. The little ceramic chip glows and the burners ignite. This lasts for about 5 seconds. Then, when the chip starts to go out, the burners all instantly snuff out and the process repeats it self. The ceramic piece is supposed to stop glowing, right? It basically seems as though the gas is being cut off.
The red light in the bottom of the unit does not blink at all (remains constantly red) and I've changed thermostats and that has done nothing either. There is a loose brown wire that is just lying on the piece of sheet metal right above the burners. It has some type of clip on it. Otherwise, everything seems normal.
Thoughts?
Thanks!
****** update: Check out a video of my furnace at and let me know what you think! Thanks!
sobro is offline   Reply With Quote
Old 10-05-2010, 01:03 PM   #2
Rewards Points: 292
Sounds like the flame is not being 'sensed'. The loose wire may have been attached to the flame sensor. See the images on the following site:
http://www.google.com/images?hl=en&s...=&oq=&gs_rfai=
The tip should be in the flame. If the sensor is in place and properly wired, try removing it and cleaning it with scotchbrite (not sand paper) and reinstalling.
V
veesubotee is offline   Reply With Quote
The Following User Says Thank You to veesubotee For This Useful Post:
sobro (10-12-2010)
Old 10-12-2010, 08:55 AM   #3
update
Ordered a flame sensor (~$22 shipped) from Shorty's in Indianapolis and it worked! Thanks again!
Old 10-12-2010, 09:22 AM   #4
Rewards Points: 292
Glad it worked out for you.
An annual 'cleaning' as I indicated is a good idea.
V
Tags
furnace , gas , ignition , won't stay lit
Ducane Gas Furnace fails to stay on franko HVAC 25 12-08-2011 04:14 PM
Water Inside/Around American Standard Furnace michrob HVAC 8 12-08-2011 03:51 PM
bryant gas furnace burner wont stay on. pipebender HVAC 29 11-08-2009 07:41 PM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 01:55 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 01:45 AM
