Gas Furnace Venting - HVAC - DIY Chatroom Home Improvement Forum
Old 06-13-2009, 12:26 PM   #1
Gas Furnace venting
I am in the middle of a remodel in seattle and have a six 6 diameter exhaust vent for my furnace that currently runs up through the roof. My question is can I re-route the vent through the floor to vent out the side of the house instead of through the roof?
AVPIV is offline   Reply With Quote
Old 06-13-2009, 05:52 PM   #2
Being six inch I have to assume you mean a metal chimney. No you can't vent out the side with out a specialized motor driven fan system
hvaclover is offline   Reply With Quote
Old 06-13-2009, 07:07 PM   #3
sktn77a's Avatar
Rewards Points: 392
You could do this, if you absolutely must, but you would need a double wall galvanised vent pipe and an exterior power venter. Unless you positively, absolutely, must go this direction, I would avoid it as the external power venters are expensive and unreliable.
sktn77a is offline   Reply With Quote
Furnace venting questions Mastiff HVAC 9 12-05-2012 05:51 PM
High efficiency furnace venting Mnrunner HVAC 14 01-18-2009 09:25 PM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 01:55 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 01:45 AM
Options for venting 90+ furnace RM575 HVAC 2 06-17-2007 10:32 PM
