Gas Furnace Stays On 1 Minute Then Shuts Off -- Any Troubleshooting Help? - HVAC - DIY Chatroom Home Improvement Forum
Old 10-23-2009, 11:29 AM   #1
Rewards Points: 14
Gas furnace stays on 1 minute then shuts off -- any troubleshooting help?
I know this is an old unit, but I'd like to see if there is a fix. The T-stat in the house is set to 80, and the temp in the house is 70. The T-stat switch is set to "heat".
The blower motor in the furnace will come on for about 1 minute, and then it shuts off for about 1 minute or maybe 90 seconds. It just keeps doing this cycle. The pilot burner is constantly on, and the heater element turns on for about 30 seconds and then goes out for about 90 seconds. It also does this in a continuous cycle. There doesn't seem to be any relation between the blower motor cycle and the heater element cycle, but I'm not absolutely sure.
Here are a few pictures if they are any help. What are the 2 or 3 most obvious things the problem could be?
Thanks,
Endzone in Ft. Worth,TX
Endzone is offline   Reply With Quote
Old 10-23-2009, 07:00 PM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 1,108
Faulty thermostat/short cycling the burner.
Old 10-24-2009, 12:41 AM   #3
Houston204's Avatar
Rewards Points: 556
Have you inspected your evaporator coil?
Houston204 is offline   Reply With Quote
furnace ignition troubleshooting buju HVAC 22 01-14-2009 11:41 PM
Bryant +80 Gas Furnace won't light tr0910 HVAC 4 01-14-2009 08:11 AM
Goodman Furnace gas firing but shuts off digitaljim HVAC 3 12-08-2008 04:29 AM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 02:45 AM
furnace cycles, runs for 45-60 seconds shuts down and recycles again ronsmoneypit HVAC 4 02-03-2008 02:46 PM
