| DIY Forum | DIY Blogs | Photos | Woodworking | Extreme How To | Advertise | Contact Us |
Previous Thread
Next Thread
More On This Topic
How to Seal Air Leaks
by eHow.com
Air leaks are one of the most significant causes of efficiency loss in home heating. A leaky wall or poorly sealed ventilation results in hundreds of dollars of extra work by your heating or air conditioning unit. Sealing an air leak is not an easy task... Read More »
Checking Sealed Insulation for Home Insulation
by Expert Village
Hi! My name is Joshua Lindsey with CFM Building Science Solutions. On behalf of Expert Village, we are doing a frame walk and insulation inspection on this home. In talking about insulation, one area that we need to cover is how well your house is sealed... Read More »
How to Winterize a Mobile Home
by eHow.com
If you're living in a mobile home and facing your first winter, you may not be aware how difficult it can be to keep a mobile home warm. Taking the proper steps to winterize your mobile home cannot only help keep you warm, but keep your heating bills... Read More »
How to Repel Hornets
by eHow.com
Hornets live in nests that have one opening. They remain in the nest at night. When a single hornet is killed, it releases a pheromone that signals others to attack. These insects build nests in trees and shrubs. They eat many insect pests but because of... Read More »
How to Seal a Sink
by Expert Village
I’m Lee. I have a degree in architecture and about ten years construction experience. We just installed a sink from, probably from the fifties, into a house from the seventies. And what we want to do is seal everything up around the drain pipes and... Read More »
