Gas Furnace Ruud Super Quiet 80 Ignition Problems - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 10-18-2011, 10:24 AM   #16
I'm Your Huckleberry
Rewards Points: 2,270
Elsinore, the draft inducer is always the first thing to come on in heatng mode. That hose that attaches from there to the pressure switch, if bad, is not allowing the switch to close. It could be that or that switch is gunked up and is not closing. Without that switch closing nothing else will work. The switch allows for continuity, an elecrical signal to pass through, to go back to the control board, telling it that the exhaust side of the furnace is working properly so go ahead and light the burners for flames.
A furnace will not light up until it proves to itself that it can exhaust those burned gases.
Check that hose and switch if the inducer is coming on.
Doc Holliday is offline   Reply With Quote
Old 10-18-2011, 10:42 AM   #17
Yes that fan does come on.
Elsinore is offline   Reply With Quote
Old 10-18-2011, 10:44 AM   #18
I have cleaned out the hose and the entrance it goes into. It has two switches how would I know if they are bad?
Old 10-18-2011, 10:49 AM   #19
Then pull the doors off of the furnace, remove the hose from the inducer, not the switch, and with the furnace door safety switch taped down or pushed in (you'll see the door switch under the door on the furnace once you remove said door) and the stat calling for heat, suck hard on that hose. If you sucking on the hose while the inducer is running closes that switch and the burners come on then it's either the hose or the switch.
I know it sounds funny but it it what it is. The draft inducer motor produces suction through that hose to pull the spring closed in the switch, allowing continuity of that electrical signal to go back to the board, allowing the furnace to ignite.
Old 10-18-2011, 01:24 PM   #20
Yes the fan comes on for a while, then everything shuts down.
Old 10-18-2011, 02:15 PM   #21
So did you try what I stated earlier?
Operation
  • When a furnace begins a new cycle, the draft inducer blower fan begins whirring 30-60 second before the furnace burners actually ignite. The fan motor must also run properly and usually has a safety pressure switch connected to the fan housing. Pressure switches ensure that the motor is running according to the manufacturers' specifications. If the inducer fan motor cannot turn on, the furnace will generally shut off and lock out. Several other reasons may also cause the draft inducer blower to ultimately shut down a furnace. These include a faulty pressure switch, a bad rubber tube component, or there may be a blockage in the gas vent flue, or even the blower itself may not be working properly.
Read more: What Is a Furnace Draft Inducer Blower? | eHow.com http://www.ehow.com/about_6648692_fu...#ixzz1bA8BNvBs
Ruud Furnace issue grubslinger HVAC 16 09-14-2011 12:13 AM
Perplexing problem, Ruud furnace jbarker HVAC 43 01-20-2010 12:03 PM
Furnace Problems? MCSE HVAC 10 12-20-2006 11:06 AM
Furnace Problems? Part 2 MCSE HVAC 9 11-30-2006 09:25 PM
Intermittent gas furnace problems dcoz HVAC 1 01-16-2006 09:22 PM
