Old 10-16-2010, 02:32 PM   #1
Unhappy
Gas furnace running but no hot air
HI
we have a gas furnace, on the thermostat it shows as the furnace is on and running but there is no hot air. the temperature has dropped. It was working well and suddenly it stopped in the morning. Our furnace is almost 10 yrs old now.Anybody can tell me what might be wrong. Is there anything that i can check before calling someone, would be nice if I don't have to call anyone-- its really expensive. Thank u all in advance.
newone is offline   Reply With Quote
Old 10-16-2010, 02:43 PM   #2
HVAC / Plumbing
It it has a control board . See if it has a small light. If it blinks count the blinks . look on the back of the blower panel & see what the code is
kenmac is offline   Reply With Quote
Old 10-17-2010, 02:53 PM   #3
it says normal operation -- when heating demand initiated at the thermostat
Old 10-17-2010, 04:08 PM   #4
HVAC / Plumbing
If it has HSI check to see if it's glowing red to ignite the gas.
Old 10-18-2010, 06:54 AM   #5
yes it is
Old 10-18-2010, 09:08 AM   #6
Electrician
SD515's Avatar
Natural gas or LP? If LP, is there fuel in the tank? I did a service call once that all it needed was a refill of the LP tank.
Kyle
Old 10-18-2010, 10:23 AM   #7
Its natural gas
Old 10-18-2010, 11:21 AM   #8
HVAC / Plumbing
check limits, ps, 24 v at gv
Old 10-20-2010, 10:45 AM   #9
thanks I had it done with somebody cos it was getting really cold at home
Furnace air filtration advice stephen_smith HVAC 7 12-24-2010 03:24 AM
When running furnace on fan only..... Zombify HVAC 10 12-23-2010 07:58 PM
Gas Furnace Fan Occassionally Keeps Running After Burner Shutdown Dr_Zoidberg57 HVAC 18 11-10-2010 09:52 PM
Oil furnace does not fire up sbhavinm HVAC 5 01-17-2009 08:06 AM
Olsen BFL 120 Furnace DaleB HVAC 12 12-19-2008 11:42 PM
