Old 01-05-2013, 10:41 AM   #16
An old Tradesmen
Gas Furnace Replacement Questions
Originally Posted by carmon View Post
bye 3/4 of an 80.....
3/4 of 80 is 60.
The Following User Says Thank You to beenthere For This Useful Post:
carmon (01-07-2013)
Old 01-05-2013, 11:23 AM   #17
Roofmaster
A Question for the Pros: Is the glowing red hot HSI figured in the efficiency rating of a furnace? I cannot see for the life of me how a dead short every time the furnace starts can be considered efficient, especially if the furnace short cycles. Elements that get red hot from resistance spin an electric meter like a top.
" A lot of men build things, and a lot of things fall down "
Old 01-05-2013, 11:46 AM   #18
An old Tradesmen
The HSI uses about 3 watts in 30 seconds. Or the same as 6-60 watt incandescent lights on for 30 seconds.
Old 01-07-2013, 10:39 PM   #19
So the local father and son outfit came back with the price for a new furnace. Actually, they never did get back to me - I called them tonight. The guy said he mailed the estimate...but it never made it to me. I live 3 blocks away : )
I asked him to just relay the info over the phone so he did. They gave me four options:
York Single Stage Model # g8s060a12mp11 - $2688
York 2 Stage Model #: tm8v060a12mp11 $3295
Goodman Single Stage - $2500 (I didn't get a model #)
Goodman 2 Stage - $2674
All units come with 5 yr parts/2 yr labor/20 year heat exchanger warranty
I was stoked about these prices until I told him I'd look up the York models online and get back to him....that's when I found out that these are 80% efficient models. I had told them when they were here I was looking for a high-efficiency 2 stage model. I plan on being in this house for at least 10 more years.
To recap from the original post, here were the other estimates from the other companies I had out:
Contractor A:
Bryant 80,000 BTU, 96% 2-Stage with an X-13 High Efficient Motor (Model # 925TA048080S17)
$4600
Contractor B:
Bryant 100,000 BTU, 95% 2-Stage "with high efficiency ECM blower motor" (Model # 925TA48100E21)
$4700 ($200 coupon brings down to $4500)
Contractor C:
System 1: Carrier Comfort Series, single stage burner, standard fan 92% (Model #59SC2A100)
$3748
System 2:
Carrier 59TP5A100E21
2 stage burner
96.7% AFUE
single speed blower
$5420.00
System #3:
Carrier 59TN6A100V21
2 stage burner
96.7% AFUE
Variable speed blower
$5907.00
I'm pretty sold on the 2 stage option, as the last couple of weeks I've noticed that the current 80% 1 stage furnace heats the house quickly and then when it's off, the house feels noticeably cold, and then the cycle repeats.
As of now, I'm thinking Option A: the 80k BTU 96% Bryant for $4600. I emailed the guy and asked if he would honor the $200 coupon from the other place and am hoping he will. If so, that would bring it down to $4600, plus a $300 utility company rebate (just got notice in the mail today, with the utility bill, that the rebate only applies to 95%+ Energy Saver furnaces, effective the start of this year).
What do you guys think?
mark2741 is offline   Reply With Quote
Old 01-07-2013, 10:51 PM   #20
An old Tradesmen
Sounds ok. Being 2 stage you will get better comfort. but at 80,000 BTUs, its probably still over sized.
The guy that gave you prices on 80% equipment was only installing 60,000 BTU furnaces.
Old 01-08-2013, 12:58 AM   #21
80% really..... they still make those gas guzzlers.......:whistling2 :
carmon is offline   Reply With Quote
Old 01-08-2013, 01:30 AM   #22
Not every country can be as perfect as Canada.
hvac benny is offline   Reply With Quote
The Following User Says Thank You to hvac benny For This Useful Post:
HVAC1000 (01-09-2013)
Old 01-09-2013, 12:25 AM   #23
Experienced HVAC Tech
yeah and not even all of the U.S.A. is illegalizing 80%ers but hey somewhere has got to remain the wild west
HVAC1000 is offline   Reply With Quote
Old 01-09-2013, 11:27 AM   #24
Roofmaster
In this day of rising energy costs, and the threat of Global warming, why would anyone hurry up and use an 80% efficient furnace, when 95% + Furnaces are out there? The payback on an additional 1k or so has to be about 3 years? Going 80% seems extremely short sighted to me.
The intake and exhaust for HE is 3 inch PVC. Relatively Inexpensive.
My HE had an elaborate condensate line run all over the place. I took my trusty Hilti TE-12 and drilled a 1/2 inch hole down through my basement floor. Caulked a plastic container to the floor to catch the condensate, done. Most basement floors have clean stone under the slap that can easily take the clear water condensate from a furnace.
However: Considering the posts I have read in the HVAC forum here, and the increased complexity of HE furnaces with variable speed motors, multi stage gas valves, multiple pressure switches, there seems to be a precipitous drop in reliability, probably due to the manufacturers trying to drive down the price of these components. Chinese motors, thin copper tubing, etc, etc. is sure to increase the amount of service work for HVAC literate techs. Looks like a bright future for an HVAC tech that stays up on all the latest problems.
Is anyone creating a data base of specific problems based on MFGR?
Old 01-09-2013, 04:21 PM   #25
An old Tradesmen
there are those areas that only need heat for a few weeks, or the outdoor temps are very mild, and a 90% furnace would take 10 or more years just to recover the additional cost of the 90%er.
Old 01-09-2013, 11:29 PM   #26
Yes but when you are selling these units to customers they do not necessary see the benefits to overcome the additional $2000 after installation (we need to make money too, 90%ers take longer to install so we need to charge more for our time and knowledge and additional material) , especially if it is a rental house, why would the landlord volunteer the extra money if they don't even get the benefits of it or pay the utility bills for it.
PVC may be easy and inexpensive to run in a crawl space attic or unfinished basement but running new pipes in a finished basement it is one of the most frustrating things you will ever do.
And in my area and I'm sure many other areas it is illegal to just dump condensate in a hole in the concrete of your basement.
Yes the cheap manufacturing of parts may generate multiple service calls but if you installed the unit then it makes you look bad for installing something that keeps breaking. And if you have to keep coming back even if it is for different part that break it still makes it look like you didn't fix it. Even though you did. Also at my company at least we give warranties on installations so we wouldn't be making money on the fixes anyway. This is just me but I enjoy installing quality equipment that doesn't break and doesn't make the customer go broke. 90 s are great but 80s are a real easy to install dependable workhorse.
Old 01-10-2013, 12:17 AM   #27
Missouri Bound's Avatar
huh?
Do you want it your way or the right way?
Old 01-10-2013, 05:34 AM   #28
An old Tradesmen
Originally Posted by Missouri Bound View Post
huh?
Thats how much electric it uses. Some use a little more, some use a little less.
Do the math your self. 120 volts supply, 80 ohms of resistance. 30 seconds that its energized.
Old 01-10-2013, 12:36 PM   #29
Oh I can do the math....just can't see how 3 watts in 30 seconds can be the same as 6-60 watts in 30 seconds. No math makes that work.
Old 01-10-2013, 01:32 PM   #30
6x60 = 360 watts/hr /60 min = 6 watts/min
3 watts in 30 sec = 6 watts/min
looks the same to me
HVACDave is offline   Reply With Quote
The Following User Says Thank You to HVACDave For This Useful Post:
beenthere (01-10-2013)
Some questions regarding furnace replacement Allears HVAC 3 05-27-2012 03:26 AM
Why might current PVC pipe be unusable for replacement furnace? Vaandjay HVAC 18 12-21-2010 11:11 PM
Are "Genuine OEM" replacement parts necessary for a furnace? hvacdiy HVAC 3 11-19-2010 10:09 AM
replacement part for Aire-flo furnace? BlueBSH HVAC 9 09-14-2010 09:41 AM
Advice needed. Complete Furnace & duct replacement - asbestos ductwrap (crawl space) vestaviascott HVAC 11 03-10-2009 06:40 PM
