Gas Furnace Problem - HVAC - DIY Chatroom Home Improvement Forum
Old 12-01-2009, 11:18 AM   #1
Gas Furnace problem
I have a Payne gas furnace. Over the last couple months there have been times where the thermostat is calling for heat and it won't come on. I go to the furnace and give it a nudge and the fan kicks on and away it goes.
Any suggestions?
mfreamon is offline   Reply With Quote
Old 12-01-2009, 03:41 PM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 386
Its a Pain LOL. Post the model # and a pic of it. May be that the lower door is loose, has a door switch behind it.
Old 12-01-2009, 06:19 PM   #3
Houston204's Avatar
Rewards Points: 556
I'd have to ask where are you nudging?
Does it display a trouble code when this occurs?
Houston204 is offline   Reply With Quote
Old 12-02-2009, 09:25 AM   #4
Thanks for the replies but I think I solved the problem. I pulled off the lower cover and found a loose red wire. I'll see what happens now. Thanks again
Heil Furnace Burner Problem timothyr HVAC 79 02-12-2014 07:01 PM
Old Silver-Line furnace problem avro1 HVAC 9 03-18-2010 12:01 AM
Strange Problem with My Furnace chenjijc HVAC 14 11-04-2009 09:05 PM
Carrier Furnace Problem Boats1183 HVAC 1 11-11-2008 06:41 PM
another question for a miller furnace problem jb9270 HVAC 1 02-05-2007 02:04 PM
