Gas Furnace Problem - HVAC - DIY Chatroom Home Improvement Forum
Old 01-21-2013, 10:30 AM   #1
Gas Furnace Problem
I have an Inter City Products gas furnace Model No NUG125BHA1. I recently replaced the blower motor but the unit continually shuts off well before reaching the temperature set on the thermastat. The auto igniter properly starts the burner, the blower then starts working. However, the burner shuts off after a few minutes but the blower continues to blow even as the air begins to cool. After a few minutes, the burner starts again and the cycle continually repeats itself. The thermastat has been checked and appears to be working properly. Any suggestions?
bph0712 is offline   Reply With Quote
Old 01-21-2013, 11:00 AM   #2
Rewards Points: 492
Clean flame sensor?
diyorpay is offline   Reply With Quote
Old 01-21-2013, 12:30 PM   #3
Sounds like you're going out on high temp limit. With you having changed blowers I'd look at what speed you used, you may want to switch to a higher speed. Other than that look at filters or anything else that would restrict airflow.
JScotty is offline   Reply With Quote
Old 01-21-2013, 12:51 PM   #4
Hvac Pro
yuri's Avatar
Rewards Points: 1,434
you may want to get it inspected by a experienced Pro as LOTS of them have cracked heat exchangers or popped out rivets that hold the exchanger together.
Old 01-21-2013, 01:19 PM   #5
Thanks for suggestions. I will try a few and update status later.
Old 01-21-2013, 06:17 PM   #6
Rewards Points: 582
agree with yuri...have furnaced inspected for damaged heat exchanger ..cracked..or rivets poped off.. inner city had problems with heat exchangers..ben sr
Heil Furnace Burner Problem timothyr HVAC 79 02-12-2014 08:01 PM
Gas Furnace Hiccups hugocraft HVAC 2 12-22-2012 07:50 AM
Quote for new furnace. Reasonable? dengle HVAC 16 03-04-2012 08:01 AM
Help with furnace blower problem Spydey HVAC 6 12-15-2010 09:18 PM
Old Silver-Line furnace problem avro1 HVAC 9 03-18-2010 01:01 AM
