Gas Furnace Problem - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 10-11-2012, 11:14 AM   #16
i will check those when i get home, does anyone know if there is a schematic for the control board? the part number i found is 18099-13s or a substitute part # of B1809913s
Kissfan4 is offline   Reply With Quote
Old 10-11-2012, 11:37 AM   #17
how
Rewards Points: 1,104
Hey Flyer
I'm not getting your reasoning on a faulty transformer considering the furnace start up?
how is offline   Reply With Quote
The Following User Says Thank You to how For This Useful Post:
ben's plumbing (10-11-2012)
Old 10-11-2012, 02:37 PM   #18
The transformer provides 24 volts. The draft inducer and hot surface igniter run off of 120 volts. He stated that the draft inducer would run and the HSI would glow but gas valve would not open.
Flyers28 is offline   Reply With Quote
Old 10-11-2012, 04:54 PM   #19
I didn't even think about it when I posted that but I checked the voltage to the pressure switch and I got 24v, that's why I need the schematic for the board, so I can see where the power for the gas valve goes between the transformer and 9 pin plug that attaches to the board
Old 10-11-2012, 06:14 PM   #20
how
Hello Flyer
So just what runs the thermostat to get all this going?
Old 10-11-2012, 07:15 PM   #21
When there is a call for heat the circuit between r and w in the control is closed. It the sends 24v through all the safety switches and eventually to the gas valve providing the 24v to open the valve.
Old 10-11-2012, 08:03 PM   #22
how
So as the transformer is providing 24V for this furnace to be cycling as far as it does, why are you suggesting for the OP to verify that the transformer is working?.
Old 10-12-2012, 10:17 PM   #23
ok so i unhooked the two wires from the gas valve and hooked them to my meter and tried to call for heat, and as soon as i did i read 18v, is there a relay on the board that could be stuck closed or something?
Old 10-13-2012, 12:24 AM   #24
Rewards Points: 616
18v to low....
carmon is offline   Reply With Quote
Old 10-13-2012, 10:28 AM   #25
having the same problem with my Goodman furnace,model #GMC-075-3, and so is my mother and another homeowner i know with the same units. mine was installed in 94, and has run well for years. My mothers and friends units are newer, but have also run well for years. So i believe power wiring and low voltage wiring are good and have checked that angle. Sometimes my furnace (and the others) starts fine, runs well for a time, then main burners shut down in the middle of a "call for heat", main burner still running, plenum temp ok. checked voltage to valve, HSI is good, combustion fan runs good, main blower runs good, filter clean (monthly),ducting and outlets clear and free of obstructions so it is not a high temperature due to low air flow problem causing intermittent problem. I tend to think there is a common problem with these units at the controlling "mother-board", which is mounted on the fan housing. would be interested if anyone out there has seen this, and has an answer. my money is tight as well and will do any work myself to fix, but curious if this is more common than i thought.
im a kiss fan too.
28balancer is offline   Reply With Quote
Old 10-13-2012, 05:08 PM   #26
I have read on a few websites that the control board in these furnaces are known to go out, I just wish I could figure out what is wrong cause I can get a board for it but I don't have the money to just throw parts at it. I really don't want to put a 130 dollar board in it to find out it needs a 80 dollar gas valve. But hey sitting here trpubleshooting the furnace listening to the new KISS album lol
Old 10-13-2012, 05:14 PM   #27
Rewards Points: 616
im a kiss fan too.
woe double supersized caps.....shut them off...lol
Heil Furnace Burner Problem timothyr HVAC 79 02-12-2014 07:01 PM
Help troubleshooting furnace problem robert_ HVAC 21 02-15-2012 08:04 AM
Help with furnace blower problem Spydey HVAC 6 12-15-2010 08:18 PM
Furnace Model # Feh-015-04 clicking but not turning on? haimei HVAC 1 12-14-2010 05:01 PM
Old Silver-Line furnace problem avro1 HVAC 9 03-18-2010 12:01 AM
