Gas Furnace Problem - HVAC - DIY Chatroom Home Improvement Forum
Old 10-09-2012, 09:52 AM   #1
Gas furnace problem
Ok so I attempted to turn my furnace on last night since it was going down into the 30's and when I did nothing happened. So I went into the basement and had my fiancÚ turn it back on, the small blower motor starts, then after a short time the pilot lights starts to glow( this is not a flame but just a piece of metal that glows orange like a glow plug) then when're whole thing shuts down. I know the problem is that the gas valve is not opening but how do I tell if it is the valve itself that is bad? There are two wires I believe that connect to the valve, a blue one and a purple one that connects to small circular things that surroun where the burners are. Please don't just suggest calling a tech. Money is extremely tight and I just can't afford to do so. Thanks
Kissfan4 is offline   Reply With Quote
Old 10-09-2012, 09:55 AM   #2
Rewards Points: 616
measure voltage at gas valve.. also insure gas is on to furnace.. should get 24 volts to gas valve....
carmon is offline   Reply With Quote
Old 10-09-2012, 10:39 AM   #3
Rewards Points: 582
there is also and on and off swicth for the gas valve on the valve it self...make sure it on...had to ask....ben sr
Old 10-09-2012, 10:40 AM   #4
is the purple wire the ground? without looking at a schematic i am assuming the purple wire i see that connects those plugs ground the valve, and if the fire comes out to far it breaks one of those plugs and causes the valve to close. sorry for the terminology but i dont know what those things are called lol
Old 10-09-2012, 03:23 PM   #5
An old Tradesmen
Rewards Points: 6,590
Look for small buttons in the middle of the small circular things(roll out switches), its a reset, try pushing them in. If one or more of them resets. then watch as the furnace runs and see if the flames change when the blower comes on. If so, you probably have a cracked heat exchanger.
PS: Stranger things have happened, so are you sure you have gas.
Old 10-09-2012, 05:43 PM   #6
Yes to the gas, I am going to check the roll out switches when I get home
Old 10-10-2012, 07:06 AM   #7
ok, so i think i have it narrowed down to the gas valve, the board was giving me 2 or 3 error codes so i checked them and each code eventually refrences back to the gas valve. the only thing im not understanding is at no part during the startup do i measure any voltage to the gas valve. if the gas valve is indeed stuck would the furnace still send the voltage to open it?
Old 10-10-2012, 07:43 AM   #8
Rewards Points: 582
what is the make of your furnace.....does it have the honeywell smartvalve system.....after reading your last post if you don't have voltage to valve perhaps it a bad relay on board...proving to be bad control board...ben sr
Old 10-10-2012, 07:59 AM   #9
biggles's Avatar
if you had 24Vs at the valve then the valve is aced the board isn't sending the 24V read the board where the valve wires connect..see if you have 24v there...your not even getting pilot gas first off
Old 10-10-2012, 11:19 AM   #10
how
Rewards Points: 1,104
If you are getting 24V to the gas valve, it should be opening.
I am not sure from your description if you actually have a pilot flame system or if its a direct ignition system for the main burners.
A photo would also confirm that we are not dealing with a smart valve?
how is offline   Reply With Quote
Old 10-10-2012, 12:10 PM   #11
there is no pilot light, it is a heating element that when triggered it glows orange to ignite the gas, i do not get the voltage to the gas valve so i am now begining to believe it may be the relay on the control board. when i get home tonight i am going to tap on the relay to see if maybe i can get it to close
Old 10-10-2012, 12:50 PM   #12
You have a hot surface igniter. It will glow and then you should hear a click from the gas valve. If there is no click the check voltage to gas valve.
Flyers28 is offline   Reply With Quote
Old 10-10-2012, 04:14 PM   #13
An old Tradesmen
Did you try resetting the roll outs.
Old 10-11-2012, 07:26 AM   #14
i did reset the rollouts, i know for a fact they are good, i never do get 24 volts to the gas valve. I can not find a wiring diagram for the control board, which i think is what is wrong with it, to find where the 24v comes from. i kow it is supposed to come out on the purple wire but thats as far as i can troubleshoot it. the furnace is a goodman, Model #GMPN120-5 Revb
Old 10-11-2012, 12:02 PM   #15
Check the 24 volt transformer inside the blower cabinet. Also check the fuse on the circuit board if it had one.
Heil Furnace Burner Problem timothyr HVAC 79 02-12-2014 08:01 PM
Help troubleshooting furnace problem robert_ HVAC 21 02-15-2012 09:04 AM
Help with furnace blower problem Spydey HVAC 6 12-15-2010 09:18 PM
Furnace Model # Feh-015-04 clicking but not turning on? haimei HVAC 1 12-14-2010 06:01 PM
Old Silver-Line furnace problem avro1 HVAC 9 03-18-2010 01:01 AM
