Gas Furnace Plenum - HVAC - DIY Chatroom Home Improvement Forum
Old 11-01-2011, 07:38 AM   #1
gas furnace plenum
How big does my plenum need to be for my 80,00 btu upflow gas furnace
stump42 is offline   Reply With Quote
Old 11-01-2011, 08:05 AM   #2
the length and width is already determine for you by the supply opening
the height should be at least 40 inches, if you make it smaller you will lose air flow
bungalow_steve is offline   Reply With Quote
The Following User Says Thank You to bungalow_steve For This Useful Post:
ben's plumbing (11-01-2011)
Thermostat issues on old furnace - questions before I replace thermostat. Calab HVAC 11 02-18-2012 08:43 AM
Water Inside/Around American Standard Furnace michrob HVAC 8 12-08-2011 03:51 PM
Oil furnace does not fire up sbhavinm HVAC 5 01-17-2009 07:06 AM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 01:55 PM
Removing Extended Plenum Calm_Blue_Ocean HVAC 15 01-07-2008 05:22 PM
