Gas Furnace Not Firing - HVAC - DIY Chatroom Home Improvement Forum
Old 02-21-2013, 01:42 PM   #1
Gas furnace not firing
From last night, the furnace (Amana Air command 80) stopped firing when the thermostat calls for heat, the fan kept on blowing air. The LED on control module (White Rodgers 50E47-843, which replaced with original one 2 yrs ago) is always OFF. In the manual, there is two different clues:
1. OFF: Internal Failure.
2. After calling for heat, yellow LED should light for 2 seconds, if no, check Low Voltage to module (TH-TR). If no voltage:Check Limit Switches, check vent pressure switch (if used).
Should I check limit/pressure switch, or replace control module?
Thanks!
Eric
ericzy01 is offline   Reply With Quote
Old 02-21-2013, 07:50 PM   #2
Rewards Points: 582
Thanks!
Eric
check the limit and pressure switch 1st..... make sure they are working ..ben sr
Propane Furnace - Diminishing Gas Supply After Ignition edro HVAC 9 01-13-2012 05:24 PM
Older GE furnace not firing up jax1lightning HVAC 6 10-23-2010 06:26 PM
Furnace not firing jax HVAC 5 02-22-2009 01:41 PM
Problem with Trane gas furnace quovadis HVAC 17 12-22-2008 02:12 PM
Goodman Furnace gas firing but shuts off digitaljim HVAC 3 12-08-2008 04:29 AM
