Gas Furnace Not Firing - HVAC - DIY Chatroom Home Improvement Forum
Old 10-05-2012, 01:02 PM   #1
I have a 1989 Snyder General Furance, Model # GUG094A012N, that is not firing. It ran find last season. Power is on, I can get the fan motor to run but nothing is happening on the heat/gas side. I've taken the front panel off and engaged the power switch (?) but other than a click I'm getting nothing. Any suggestions?
winsox is offline   Reply With Quote
Old 10-05-2012, 02:56 PM   #2
Fixed
Got it working!
Old 10-05-2012, 03:36 PM   #3
Rewards Points: 610
Don't keep us in suspense! What was wrong. Did you just forget to turn it onto "heat"...That's OK ..you can tell..nobody will ever know
techpappy is offline   Reply With Quote
Old 10-05-2012, 04:17 PM   #4
What did I do
Amazing what happens when you lite the pilot!
The Following User Says Thank You to winsox For This Useful Post:
techpappy (10-05-2012)
Propane Furnace - Diminishing Gas Supply After Ignition edro HVAC 9 01-13-2012 05:24 PM
Older GE furnace not firing up jax1lightning HVAC 6 10-23-2010 06:26 PM
Furnace not firing jax HVAC 5 02-22-2009 01:41 PM
Problem with Trane gas furnace quovadis HVAC 17 12-22-2008 02:12 PM
Goodman Furnace gas firing but shuts off digitaljim HVAC 3 12-08-2008 04:29 AM
