Gas Furnace, No Heat, Can Smell Gas In The Crawlspace - HVAC - DIY Chatroom Home Improvement Forum
Old 12-19-2009, 07:14 PM   #1
Gas Furnace, no heat, can smell gas in the crawlspace
Unfortunately, I don't know the model because it was taped over at some point.
It's a gas furnace with electric ignition (no pilot). I removed the programmable thermostat from the wall for repainting, then the house was without electricity for approx 2 months. New tenants moved in and the heat did not work. Replaced batteries in the thermostat and the heat started working.
Couple days later, no heat again. Replaced the air filter, which was very dirty. Here's the current symptoms:
* Thermostat 'Off', Fan 'Auto' -- nothing
* Thermostat 'Off', Fan 'On' -- the system blows air out the vents
* Thermostat 'Heat', Fan 'Auto' -- i can hear noise as if the furnace turns on, but no air flow to the vents
* Thermostat 'Heat', Fan 'On' -- same noise as above, plus cold air blowing
In the crawlspace, I can smell natural gas. So it seems like there is no ignition going on. I'm planning on calling a pro tomorrow, just posting here in the off chance that there is something I could try first.
dr_tunes is offline   Reply With Quote
Old 12-19-2009, 08:59 PM   #2
An old Tradesmen
Rewards Points: 7,278
Since your smelling gas in the crawlspace.
Might be better to have a tech look at it. One spark at the wrong time. And well, you don't want to have that happen.
Shut gas valve off to furnace, until tech gets there.
Old 12-21-2009, 07:37 AM   #3
simple fix, needed new ignition.
Musty crawlspace smell coming into house tmpyankee HVAC 6 08-20-2015 09:46 PM
Replace Heat Exchanger or Furnace deccher HVAC 41 10-22-2013 08:45 PM
exhaust smell when the furnace kicks on puchead77 HVAC 5 01-19-2009 01:11 PM
What heat range should I expect from my Furnace? Winchester HVAC 16 12-09-2008 03:36 PM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 01:55 PM
