Gas Furnace Making Loud Buzzing When Heat Flipped On - HVAC - DIY Chatroom Home Improvement Forum
Old 10-26-2010, 09:58 PM   #1
Question
Gas Furnace Making loud Buzzing when heat flipped on
Hello
I have a York Stellar Plus, Model: P2UDD12NO9501C
I believe its under 20 years old maybe under 15
When I hit the heat on the thermostat the furnace emits a loud buzzing noise
What could this be?
Will it be expensive to fix? Is it something I can do myself?
It sounds like the buzzing is coming from the motor area when I take the cover off.
Thank You
Bob26003 is offline   Reply With Quote
Old 10-26-2010, 10:35 PM   #2
Have a service tech check it. It could be the motor, relay, bearings, blower wheel etc..
Artco is offline   Reply With Quote
Old 02-17-2012, 08:04 AM   #3
there are two relays in front of the motor in the control box area these are magnetic switches and you might have a defective one
MAPSTER is offline   Reply With Quote
Old 02-17-2012, 10:56 AM   #4
mapster why are you posting on a 2 year old thread?
dosy777 is offline   Reply With Quote
Old 02-17-2012, 11:11 AM   #5
sorry I'm new to this just trying to help
Old 02-17-2012, 02:59 PM   #6
An old Tradesmen
Rewards Points: 8,194
In the first post of a thread, just above the posters name, is the date that poster made the thread. Just look at that before making a post/reply.
Also, might want to make sure you have your settings that the newest threads show up first on the forum page. Helps to eliminate the old thread mistake.
The Following 2 Users Say Thank You to beenthere For This Useful Post:
how (02-17-2012), hvactech126 (02-17-2012)
Old 02-17-2012, 03:49 PM   #7
Smile
gas furnance making loud buzzing when heat turned on
Hey Bob: I had the same problem. I changed the capacitor and it worked for a little. It was actually the motor and was dirty , I cleaned both but didn't work and had to buy a new motor and bracket which was old and riveted and couldn't tighten it. Now running smoothly. Check if there are any parts store that will sell you one or you can buy motors online as well. techs will tell you the motor is 500.00 not! got mine for 95.00 and a capacitor for $5.00. magicpatrick1 on youtube has alot of videos and how to change and clean etc. make sure you balance the blower wheel with even spacing on either side ,watch your fingers. Hope this helps somewhat. Also, some parts store if you disconnect the wires and keep it in the assembly housing will tell you if it is the motor by testing it at their store. I don't know if you have abcsupply there.
mariamav3 is offline   Reply With Quote
Replace Heat Exchanger or Furnace deccher HVAC 41 10-22-2013 08:45 PM
Gas Furnace, no heat, can smell gas in the crawlspace dr_tunes HVAC 2 12-21-2009 07:37 AM
Loud vibration of indoor coil in heat mode john-hvac-new HVAC 3 11-03-2009 09:27 AM
Furnace Fan is loud...suggestions needed robmypro HVAC 5 09-28-2009 04:22 PM
Steam Heat still making banging noises helpless handyman HVAC 101 01-04-2008 03:43 PM
