Old 03-12-2009, 10:04 PM   #1
Gas Furnace loud during ignition
Hello,
We have a Coleman Evcon gas furnace that is pretty loud during ignition. It has a hot surface ignitor. As it lights, the sound of the gas igniting is a pretty loud whoosh, louder than it was a couple of years ago. Seems louder than makes sense. I have read that the burners may need to be cleaned. Can I just take the two tubes off the end and clean them, or should other things be cleaned?
Thanks...
biggles99 is offline   Reply With Quote
Old 03-12-2009, 10:08 PM   #2
This is a picture of the furnace from my prior message.
Old 03-12-2009, 10:26 PM   #3
Hvac Pro
You can remove them and clean the carbon buildup gently from the ends with a bristle brush/toothbrush. Then rinse them in hot running water/dry and reinstall them. There are small crossover slots which may need gentle cleaning also.
Old 03-14-2009, 04:48 PM   #4
Just remove the two funnel shaped pieces? Is there anything about the supply tube that I should also get with the toothbrush?
Old 03-14-2009, 05:30 PM   #5
Hvac Pro
No. Usually you can remove those hold down screws on the burner and slide them forward. BE CAREFULL not to hit and break the igniter.
Old 11-12-2011, 07:37 AM   #6
Update: I have tried this a few times, and it is still as loud as ever...not every time, but about 1/2 the time. When the gas ignites, it does with a rather loud whoosh as the gas ignites. Trying to think if it is something about the rectangular module that has the switch that looks like a small valve in it.
Had a furnace guy come out last year and he did not really do anything, other than adjusting that little lever a bit, which I think regulates the flow of gas.
I am thinking that somehow that whole thing needs to be replaced, if it is it, but not sure that is safe/possible to get someone to do?
Anyone ever replace that part of a furnace, outside of just replacing the whole furnace?
Old 11-12-2011, 08:18 AM   #7
raylo32's Avatar
Just a thought... maybe the ignitor is heating up a little slow or is a little weak? If so maybe the whoosh is caused by a little bit more gas getting out before ignition actually happens.
raylo32 is offline   Reply With Quote
furnace ignition troubleshooting buju HVAC 22 01-14-2009 11:41 PM
Loud furnace ignitor! Genhawk21 HVAC 2 01-12-2009 05:11 PM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 02:55 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 02:45 AM
