Old 03-31-2009, 10:19 AM   #1
gas furnace keeps running thermostat off
Help! New to gas and having serious problem. Tried replacing Honeywell digital thermostat batteries, tried reprogramming all temps multiple times. Turned off thermostat, gas keepis running temp at 80 degrees. Finally out of deperation and perspiration, I had shut off the furnace switch. I must leave for work now and I am not looking to waste more costly fuel in having summertime temps in my NY home. Can anyone help? The gas furnace is a HydroTherm HC-125C, not sure how old.
cblake is offline   Reply With Quote
Old 03-31-2009, 01:55 PM   #2
HVAC / Plumbing
If all worked ok until you replaced t.stat ...You have the t.stat wired wrong Sending voltage to the gv at all times
kenmac is offline   Reply With Quote
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 02:45 AM
furnace blower keeps running dmbrasket@hotmail.com HVAC 7 02-03-2008 04:57 PM
New Thermostat and Furnace Not Working Right Vegas Resident HVAC 1 12-06-2007 07:42 PM
Oil Furnace - Swapping out to Programmable Thermostat slappy HVAC 2 12-05-2007 04:57 PM
