Gas Furnace Issues..No Heat, Lots Of Cold - HVAC - DIY Chatroom Home Improvement Forum
Old 12-06-2011, 08:43 PM   #1
Gas Furnace Issues..No Heat, Lots of Cold
Our gas furnace recently stopped working. One day it was fine, the next it doesn't work. A little background info: Thermostat is a Maple Chase, Furnace Door says Rheem Criterion Installed 1992. I have no manuals. I did change the filter but that did nothing. If I turn the fan to On, it blows very well but only cold air. I have noticed the the pilot light seems to be out. If I flip the breaker, the furnace will come on for about 5 minutes and blow cold air then shut off. Gas water heater works fine. I am a complete novice at home repair but would like to avoid the cost of calling a pro if I can. So if anyone can help me figure this out, it would be wonderful. We're surviving with space heaters that take all day to heat the house and have doubled our heating bill.
otakumom is offline   Reply With Quote
Old 12-06-2011, 08:57 PM   #2
Rewards Points: 582
sounds like you need and ignitor.......when unit starts inducer motor runs then ignitor glows burnners light starts to heat.....
Old 12-06-2011, 09:39 PM   #3
biggles's Avatar
you might have an spark ignition like on the stove top pop the top panel to expose the burner and controls check for a disc with 2 wires on it mounted near the burner opening(just where the flame comes out) might have a small RED button on it push to reset then toggle up the power on the furnace on the side...4" round silver control with 2 wires going to it tap it with a screw driver....then re power off the toggle switch on the side....make sure your stat is set for heat in auto....do you hear a sparking sound...small fan starts up first any action get back....asap
Old 12-07-2011, 06:45 AM   #4
I can certainly sympathize with you, but if you get in there and start poking around with 1. HIGH VOLTAGE and 2. NATURAL GAS and something goes wrong what will it cost then ?if you have even the working knowledge of a gas forced air furnace then we probably could get you through this......but admitting that you are a "complete novice" tells me that you should not attempt any repairs on such a complicated system.
harleyrider is offline   Reply With Quote
Old 12-07-2011, 01:53 PM   #5
Rewards Points: 338
high voltage??? last time i checked, furnaces were 120V.
NitroNate is offline   Reply With Quote
Old 12-07-2011, 05:48 PM   #6
Yes nate.....120 volts is considered high voltage......low voltage is control voltage such as a 24 vac .....
Old 12-07-2011, 06:26 PM   #7
Rewards Points: 338
all i know is the NEC defines it as over 600 volts. i suppose it's a matter of what is dangerous to a homeowner.
Old 12-07-2011, 06:38 PM   #8
HVAC Tech/ Browns Fan
I guess you use you fingers to test for voltage.
Tator1076 is offline   Reply With Quote
Replace Heat Exchanger or Furnace deccher HVAC 41 10-22-2013 08:45 PM
Heil Furnace issues KMV HVAC 5 12-09-2010 01:37 PM
Carrier Infinity 69 Trouble Code 42 bodya1 HVAC 4 12-05-2010 06:43 PM
Help with Heat Pump System Wiring AlanScott HVAC 11 10-10-2010 12:19 PM
Gas Furnace, no heat, can smell gas in the crawlspace dr_tunes HVAC 2 12-21-2009 07:37 AM
