Gas Furnace Ignition Problem. - HVAC - DIY Chatroom Home Improvement Forum
Old 10-27-2012, 03:40 PM   #1
gas furnace ignition problem.
Trane funace operates correctly through its steps untill the ignition of the furnace. The relay clicks but no ignition.
Larrymen is offline   Reply With Quote
Old 10-27-2012, 03:58 PM   #2
Houston204's Avatar
Rewards Points: 556
So you ever see a hot surface ignitor glow?
If not, does it appear damaged?
Houston204 is offline   Reply With Quote
The Following User Says Thank You to Houston204 For This Useful Post:
carmon (10-27-2012)
Old 10-27-2012, 05:21 PM   #3
I can see the glow through the site glass.
Old 10-27-2012, 08:50 PM   #4
Rewards Points: 582
if ignitor glows and you here a click that is gas valve trying to open...if it don't open bad valve..ben sr
Old 10-27-2012, 10:42 PM   #5
Houston204's Avatar
Rewards Points: 556
Do you have other gas appliances working in the home?
Is the gas cock outside of the furnace and the small switch on the gas valve in the furnace turned on?
Old 10-27-2012, 11:12 PM   #6
how
Rewards Points: 1,070
Maybe so but maybe not...
It's not really a complete picture unless one meters the gas valve feeds seperately from the gas valve. Some faulty boards will momentarily charge a gas valve just enough to cause the solinoid to engage before dropping out again. All you hear is a click from a momentary powering but the valve is perfect.
how is offline   Reply With Quote
Old 10-28-2012, 07:27 AM   #7
Rewards Points: 582
yes i agree how....but op says he hears a click...single...if powered by board for ignition you hear click ..if it drops call you should hear another click....or clicking sound.....lets wait to hear from op for more infromation....but good call..ben sr
Old 10-29-2012, 11:06 AM   #8
Question
Gas
I have made sure gas valve is on and the only click I hear is from the black relay on the circuit board. I made sure all wires were getting connection to the gas Valve. Is it common for a gas valve to fail after 7 yrs.
Old 10-29-2012, 11:19 AM   #9
how
Gas valves, like boards, can fail anytime.
You will not know which might be faulty until you measure whether the gas valve is getting 24ac Volts or not.
Old 10-29-2012, 12:59 PM   #10
If I find that the valve is not getting the required voltage would that automatically point to replacing the board?
Old 10-29-2012, 04:12 PM   #11
how
If the valve is not getting the required voltage then the board is suspect. Some folks have had success at tapping that board relay you hear clicking with a screwdriver but that is usually only a temporary fix.
The Following User Says Thank You to how For This Useful Post:
ben's plumbing (10-29-2012)
Old 10-29-2012, 04:18 PM   #12
JJboy's Avatar
If the Igniter is Silicon Nitride type. You can check the resistance ( 11-19ohms) if you measure high resistance, the igniter will glow the gas valve will open but the burners won't light.
**Always kill the power ** Hot air rises, but heat will always move from higher to lower temperatures. ** Real man shoot in manual. ** If it ain't grounded, it ain't dead.
JJboy is offline   Reply With Quote
Old 10-29-2012, 06:19 PM   #13
Rewards Points: 582
larry ..you have to confirm 24 volts at gas valve...as how said..ben sr
Heil Furnace Burner Problem timothyr HVAC 79 02-12-2014 08:01 PM
Carrier 58 RAV Furnace Problem ? fixit99 HVAC 11 12-30-2011 07:57 PM
Carrier furnace, no ignition problem gdnt HVAC 2 12-24-2011 03:37 PM
Miller G5RA furnace flame sensor problem mpit52 HVAC 3 01-16-2009 11:30 AM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 02:45 AM
