Old 08-19-2010, 01:48 PM   #1
lloydb's Avatar
Gas Furnace: How many btu's for 1500 sqf?
Im thinking of replacing my mom's furnace. How many btu's do I need for a 1500 sqf house?
I've heard 12,000 btu's per ton and it has a three ton, but 36,000 btu's doesn't sound right.
Broken Arrow hvac
lloydb is offline   Reply With Quote
Old 08-19-2010, 05:00 PM   #2
An old Tradesmen
Use HVAC CALC to determine what size furnace and A/C you need.
Standard min size blower is 3 ton. Doesn't mean that you need a 3 ton A/C.
Old 08-19-2010, 08:38 PM   #3
How cold do your winters get? How good is the insulation?
Without knowing the details a 50-70K BTU furnace should be about right.
A 36K BTU furnace would probably heat the house most of the year but it would run for long cycles and if you had a cold winter your house would likely get pretty cold as it wouldn't keep up.
zootjeff is offline   Reply With Quote
Old 08-19-2010, 08:42 PM   #4
I have gas!
Clutchcargo's Avatar
Does the current furnace keep up with the winters? If so just match up the output BTUs with the new unit.
You need the wall R values (including windows and doors) and air infiltration value to determine the output of a unit from scratch.
GL
I tear things down and build them up.
Clutchcargo is offline   Reply With Quote
Old 08-19-2010, 10:22 PM   #5
It was a dark and stormy
Yoyizit's Avatar
This
http://www.degreedays.net/
will give you the HDD for your area.
This
http://www.homeenergy.org/consumerin...ergy-usage.php
gives you a way to calculate your needs, but the tolerance on the answer is pretty wide.
Some say that 6 BTUs per SqFt per HDD is average but according to this link 52% of the homes use less than 10.0 BTUs/HDD/Sq.Ft. so they're saying ~10 is avg.
BTW, it should be BTUs/(HDD-sq.ft), not BTUs/HDD/Sq.Ft.; that is, as either HDD or sq. ft goes up, BTUs go up.
The English sentence "BTUs per SqFt per HDD" could reduce to either formula but BTUs/(HDD-sq.ft) is correct. Mostly people get this wrong or write it in a way that is ambiguous.
Old 08-20-2010, 05:06 AM   #6
An old Tradesmen
GL
Thats the one of the worst things you can do. Most furnaces are already oversized. So why stick in another oversized furnace?
Good chance his place only needs a 40,000 BTU. Or it could need a 50, or 60,000 BTU.
The idea is to get the right size. And have LONG run cycles when its near design temps.
Old 08-20-2010, 06:02 AM   #7
I live in NJ and 70,000 does good for me. At 80% efficiency usuable 56,000BTU
reckless is offline   Reply With Quote
Old 08-20-2010, 07:47 AM   #8
That's for an AC. Takes more BTU's to heat a house to maintain 72 degrees when it's 20 below out then it does to cool a house to 74 when it's 95 out.
No way to give a correct size without knowing location or how tight the house is. A modulating or multi stage furnace will give your mom the best comfort though.
Old 08-20-2010, 08:34 AM   #9
lloydb's Avatar
This is for Northeast Oklahoma. Most of the winter here is above freezing with some dips into the teens or single digits sometimes.
Broken Arrow hvac
Old 08-20-2010, 10:07 AM   #10
I have gas!
I wouldn't say it's the worst thing you can do. Taking rules of thumb from the internet is the worst thing.
I would think my method is a better barometer for sizing the next unit than estimating the R-value of the wall and how drafty the windows are.
If it's doing it's job and doesn't run short cycles, why not put the same output unit in? You just have to keep an eye on the run time during the cold spells.
If you really want to nail down the size unit the textbook "Modern hydronic heating" goes into great detail.
Old 08-20-2010, 01:48 PM   #11
In any case and any sizing you should probably just weigh the factors that are important to you.
Are you considering a high efficiency furnace or an 80%?
How annoyed will you be with a furnace that can't keep up on those one or two weeks, vs how much better you'll feel about having a lower loss furnace and saving that green energy?
A furnace that puts out less heat also puts out less waste heat, so that's why you want a long cycle and a smaller furnace to be the most efficient.
If you think you might have winter that dips into the negatives and you're worried about it to the point that it will keep you up at night because grandma might freeze to death... Then the physiological benefits of running an over sized furnace outweigh the costs.
Old 08-20-2010, 04:26 PM   #12
An old Tradesmen
Doing a load calc, is much better.
Just putting in the same size. Leads to new furnaces being over hated. Since new furnaces need to move more air then the old one did. The heat exchangers aren't made as thick as they use to be. So the temp rise needs to be lower.
Lots of houses have 100,000 BTU furnaces in them. And the house only needs a 60,000 BTU.
Using the same efficiency furnace, but sized right. Saves a lot of money on the heating bill.
Old 08-20-2010, 04:28 PM   #13
An old Tradesmen
Try doing a few load calcs. And you'll see how accurate they are.
And how oversized the furnaces you have been putting in are.
Lennox Furnace G27M Series – Unreliable operation: pressure switch or else? sheppard1977 HVAC 7 01-14-2013 06:42 PM
Water Inside/Around American Standard Furnace michrob HVAC 8 12-08-2011 04:51 PM
Furnace air filtration advice stephen_smith HVAC 7 12-24-2010 03:24 AM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 02:55 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 02:45 AM
